I had the same problem with my car, exhaust tone was nice but after driving it for 20min u get over it pretty quickly (its a sign of old age, I like to call it maturity lol)
Besides that, when the exhaust db drops, u get to hear more engine noise which is a major plus.
Wont be making the drag day, still need to make changes for it to be road worthy. As the car has been pulled apart and off the road for so long, Adam suggested that the car as a whole needs a few K's put on it just to see if there is anything that needs attention.
So far 200rwkw@10psi 5000rpm. Makes more power and torque everywhere. Feels strong.
Ordered my new plates too :)
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
I hope the rear housing will be big enough.
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
Cheers, and I am sure it will be fine... for some reason I thought you were going GTX
Ffs dont waste your time and money with the .82 housing Dave. It will only end in tears.
At the very least use a 1.06 housing and even then dont tune it without egt sensors.
You setup is almost a mirror of mine and the 33 racer car. I wont tell you how any 35r's came to grief between the 2 engines before we woke up. Using the .82 is like f**king for virginity, You wont get the desired result.
What Noel said mate! :)
But if you do manage over 400 with the .82 ill be impressed, especially if the backpressure isnt stupid and you can keep egts below 800c and stop the turbo from shitting itself the first time you go do a track day.
he did manage to pull over 400 on the RB25. topped out at 429kw from memory?
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
