Not sure If its a Chinese whisper, however, I've been told once u crack over 600awkw u would expect to pull down and refresh the engine every 5000km as the bearings lose tolerance, rods stretch etc...is this true? I was actually looking at buying an r34gtr which made over 600awkw but didn't for this reason.
Btw great result u should be ecstatic :)
Marko there is some validity to that though this can be avoided by detuning it to 599awkw but be sure to use a mainline dyno for accurate results.
+1 :worship:
I know an accurate dyno out a Giarraween :thumbsup:
Edited by GTR_JOEY
What retard told you that Marko?
maybe if it was using alloy rods as they expand more and also stretch/fatigue over time but even then good ones should last 20,000km with street/track use. though saying that, if you are going to that extent in your engine you probably arent using it on the street much if at all and are unlikely to leave the rods without checking them until one does let go.
If you look at extreme setups such as a drag car which is running thousands of HP, they need to be pulled down after each 5sec run, my mates dad has a 5sec drag car and he tells me the stories which is just mind boggling so u need to be rich with sponsorships.
Yeah I've heard it from a few guys actually but wasn't sure how true it was as to me, pulling it down every 5000km would be painful. 20000km on the other hand wouldn't be sooo bad for car which isn't a daily driver.
I was interested in buying Envy motorsports 'the jetters edge' r34gtr a while ago and he killed the sale when he told me it had its routine 5000km rebuild.
The veyron doesn't have a 5000km rebuild service interval so I'm guessing if you use the right parts, get the right person to assemble and tune it properly you will be fine?
Yeah but the veyron is an 8 Litre 16 cylinder engine. Not a 2.5 Litre 6.
Nytsky's engine is producing 91kW per cylinder, while the veyron is only pushing out 46kW per cylinder.
Thats a lot less strain on each cylinder. Also the veyron engine is built to the most ridiculous of tolerances in a humidity and temperature controlled room that is 100% dust free.
So your not really comparing apples with apples.
Nytsky, very awesome effort! However, what in the hell are you going to do with 546kW in a RWD car? lol
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
