Dark R33 (Black?), female driver i think? Turning right into Jones Rd passed Pancake Parlour Dandenong from Princes Hwy with SAU stickers. I was in a white R34 going straight across Princes Hwy from Jones Rd going onto Gladstone Rd...
ah thought i saw 34 rims... tried lookin through ur window but fark was pouring bad couldnt see shit lol
lol me being me, you wouldnt have been able to make me out through the tint anyway. and you think that was bad rain? you shoulda been on the M109 15 min b4
ADZMAX i spotted you at knox city parked near hungry jacks me and few other SAU peeps couldnt park next to you cause my mate with his bombodore took the spot haha. went to see batman its pretty good.
oh and went to FTG maccas after movies with some SAU people and ran into a black r32 with sau stickers found the owner of car in maccas lol..
Edited by b3za
I know her, shes prob to old 4 u anyway
yeh but my freind knows her, i wasnt after her lol, it was just a freindly gesture, nice car butt massive rimss lol why u assume i'm after her ferah? haha becos i waved heelllo rofl
spotted a white 33 gts-t s2 drive past me on macyntyre rd, sunshine. He had a heap of stickers on his car, but didnt see SAU sticker. he had normal plates, not custom. stock exhaust system, black rims with red inner . Looked like a fellow ethnic driver too.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
