yellow gtt with sau stickers in the city passing Ondergronds. was two cars behind a whit r33
Basti <3 lol that was me Trix_34 and my mate with r33 turbo. the r34 is N/A sorry hahaha. had a lancer with us aswell :P
Spotted a wrx and a rx7? parked at the Shell petrol station across road from Waverly Gardens
Thought u said we cant talk about other cars on the sau forums.......but since you did....
spotted a black jazz driving next to me on springvale rd - i waved at you, and you were the hot chic that flashed your big......um.....smile......
saw a black well i think it was black lol r33 with white wheels turn out of burwood kmart behind a silver 4 door, i was waiting at the lights at blackburn rd to see if u guys were doing a u turn and see what u guys were doing as i was up for goin for a drive. then i noticed the black 33 pull into bp , i was watching ya and saw u wave, i waved back but dunno if u saw me. oh yeh i was in the white R33 lol
Heaps of skylines out today
Saw CAJFLY on the corner of Blackburn Rd and Burwood Hwy, I pulled into the BP to get fuel
Heaps of cars at The Glen, white R34 GTR with the plates MAGOR, silver R32 GTR with the plates MYFAST and also a maroon R33 with the plates GTRKNG
Also so EVLGTR on Westall Rd earlier on
saw a black r33 with white wheels turn out of burwood kmart behind a silver 4 door, i was waiting at the lights at blackburn rd to see if u guys were doing a u turn and see what u guys were doing as i was up for goin for a drive. then i noticed the black 33 pull into bp , i was watching ya and saw u wave, i waved back but dunno if u saw me. oh yeh i was in the white R33 lol
haha didn't think you'd recognize me
I've been seeing that silver R34 4 door everywhere!
Basti <3 lol that was me Trix_34 and my mate with r33 turbo. the r34 is N/A sorry hahaha. had a lancer with us aswell :3some:
yeah i remember the lancer too. didja see me? car was parked right in front of the club and i was havin a smoke with my mates
lol SKYL1N you see me everywhere and I see you everywhere... That was me outside the vine. Saw your car on Elgin St in Hawthorn tonight around 11ish. Spotted a silver 33 with GTR wing at kew junction about 20 mins ago. Gave me a beep.
must be love
me on Elgin street was at a mates house getting ready to pick him up.. stingy commodore drivers and there petrol :/
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
