spotted [RESH34].. parked in lincoln square near melb uni this morning.. then driving near Rosanna station a few hours later! it was freaky
does that mean you go to melb uni too?! and i live 2 mins from rosanna station.. probs why you saw me near there !
Being spotted by someone from SAU gives me that warm fuzzy feeling hahaha
parked next to a car that was exactly my car in stock form at officeworks today...
when i looked out my window at his car it REALLY made me see how much i have lowered mine :)
was the r33gtstgtr white by any chance??
I was at the car wash the other night at the back of woodgrove in Melton and this dude in a white 33gtst pulled in behind me. he goes "awesome another GTR" I had a quick look up and saw he was in a line and said "yours GTR too?" he goes "yeah just got it" so I get up to have a look... Straight away saw it wasn't GTR as it had normal guards and gts grille. Go round the back and it had GTR badge and VSpec sticker. he goes "the guy said they are hard to find 33 VSpecs" so he bought it for $22K. I had to laugh and tell him it wasn't a GTR and he got gibbed, he argued the fact then told me my VSpecII was a old and fcked off LOL, gotta love the young and dumb hehehe
post of the year!!!!!
spot R34PER just about every weekday on Nepean Hwy somewhere between North Rd and where he does a u-turn near Freedom ;)
ahahaha do u like my U turns?? they take up 3 lanes when im trying to shoot the gap :( especially when im late for work
I work next to freedom,, at Merc
sure do mate.. living out in eltham = train only for me unfortunately :)
there is a marone r33 gts-t in my court in narre warren think they r at the party in my court wif green p plates up. very clean car. might go put a spotted card on it if its still there wen i go out.
spotted black R32 slammed with some kinda bronze rims green P Plates think it had LED tail lights as well around high street last night sometime after 10:30.
if your here can you PM me the rims your running? they are hot
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
