saw a white r34 turning on the the freeway outbound from belgrave hallam rd, and about 8 cars behind me as i was getting on the freeway had a black r32 with number plate mounted on the side, and just beofre saw a purple r33 with either a black or carbon bonnet on narre nth rd
Spotted CAJFLY along princess hwy about ten min ago...
At Springvale rd there was a broken down car in the right lane and two cars behind it... ...one pulled out on him and he locked them up... ... The next did the same to me...
It's the 4th time it's happened to me in the last 24 hours...
yeh scared the crap outta me lol i didnt wanna swerv around him incase there was a car in the other lane. sooo close, not bad for no ABS lol
spotted a series 2? r33 with a silver s1 front bar being pulled over by the cops on the western ring road this tues morning
then i saw an R32 GTR IN a warrandyte petrol station, shell.. all stock on some nice white buddyclubs?
then i spotted a white stagea in the lilydale area.. i was in the white ute with a fridge on it... lol
Spotted a silver r33 coupe last night at docklands. Very clean car.
Spotted silver r34 coupe just off Lygon with a fart cannon (it was an auto and n/a - nothing against it - just sounded really bad) - driver was trashing it and driving like a hoon. You are an idiot.
Spotted a stock looking black r34 sedan just of Lygon taking it easy.
yesterday was a nice 2 see some fellow skyliners out. Show 2 white r33 parked together down beaconsfield pde. and I was behind another white r33 with Sau sticker on the back left side window cruising down beaconsfield pdr around 11:30ish last nite. :) I was in the black 34. :)
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
