from the information i have your DETECTED speed on laser has to be 6k+ and on fixed cameras 8k+ mobile camera's are the exception, have heard of them booking you for 6k+.
Obviously cops have discretion to book you for a lower speed but i have not heard of many ppl being done for under 6k over on there detected speed, even then theres no guarantee that there not reading the alleged speed.
its 3km/h. because a couple years back i got a letter saying i was doing 78 in a 70 zone and it has written -3km/h or something like that. in the bottom line it said 5km/h over the limit or 75km/h, i cant remember exactly.
my mum got the letter first because it was in her car lol.
its definately -3... the look on the coppers face when he had to take my 121 in an 80 zone down to 118 was priceless as he had just spent 2 minutes going on and on and on about how i would lose my lisence for 6 months.... only lost it for 1 :D
and that was about 6 years agon on sth rd @ 4am btw
comming home from work down bell street had a white r33 pull out from maccaz and the turn off onto the burgandy street exit - i drove past while they were waiting to turn - looked very clean
Saw a black r34 gtt heading bak on sunbury road.
Had a SAU sticker on the passenger rear window...
i was in the 32...
Drakey, were u the guy who walked into BigW last weekend in Sunbury and recieved a compliment for a 'nice R32' from one of the girls standing at the entrance..?
I see an admin edit coming......
too right :D
spotted MRGTSR looks rice with the big wing but i think the brembo's suggest there is more to this car than rice.
bright green/yellow HR31?
Its just got a R34 Neo motor i believe
was he after a happy ending?
no idea maybe he was looking for a 24 hour krispy kreme store. all i knew was i shut my gate while he was in still @ the start of my drive way LOL
also spotted r33 with sau sticker on @ maccas ringroad.
Edited by tets
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
