B3ZA just then on Stud Rd. I was sitting in the middle lane near the Kellets Rd intersection and saw you coast by.
Sweet looking 4dr mate
thanks. having some idoling problems though when stationary (N) cars running like poo lol and its dirty :)
Spotted white R34 GTT coupe WUU*** with SAU stickers, corner Warrigul and Monash FWY exit. I was in the White r34 seden.
That would've been me. ohh it was you that i drove past . haha nice 34, very clean. I was on the way to work.
