Cr34m, B3za, How was supper???=p
LOLOL!!! was awesome.. expect to see us there more ^^ i take it that was u driving past in ur skyline.
beza waiting at the lights next to supercheap keysborough this mornin on my way to work
surprised u didnt see that orange blob car aswell.. oh hey kris!
lol..i think u and Cr34m were laughing at my nephew's masterpiece on my grill... :D
Edited by toshirokato
spotted a blue r34 with sauvic sticker but missing the 'victoria' writing under the sticker.
On nepean hwy around 3:40pm
Had some lady driving the car, stopped right next to me at the lights and snubbed me off :P Im guessing boyfriends car? or she doesnt like r32s
spotted blur-32 blue r32 on princes hwy at around 5:30pm
OMG!! no u remember now hahaha. the mustang cobra badge wasnt it? i said that was fkin epic i want one hahaha
lol, ru for real?i can give u mine if u want :) , there was once a cop came to me and say: "ru trying to be funny?"...but was not defected...lol
after muckin around on need for speed carbon for a couple of hours yesterday i went to my gf house and on the way there i saw this
if pick dont work its a white audi r8
and pretty much on a daily basis see a black 34 (unsure if 2 or 4 door due to lack of sleep) with black very spokey wheels and red walls
Had a gorgeous milenium jade R34 GTR Vspec 2 Nur catch up to me the other day on Stud Road near Kellets. Got beside me, wound down the window had a few words. Then he booted it and it was gone in a flash. Unbelievable car, cannot wait to own one of these bad boys one day :-)
Spotted a white 34 at RMIT in the city today with SAU stickers. Asian dude driving. Car looked awesome. Gave a beep as I drove past, not sure if he saw me.
that was me dude, haha .. yeah i heard your beep but i was on the phone sorry mate. your car was nice and clean! mine had bugs all over it :blush: just got back from a drive to adelaide
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
