I agree, I've seen a tuned 33 GTR blowing flames through the zorst, but the tail lights just makes you puke.
White R33 on the Greensborough Bypass this morning.. GTST and had clear LED lights in the back... seems wrong to take the red lights away...
might have seen you was this about 11.30ish and you were heading towards dalton rd?
i saw a white 34 on my way to diamond creek
was in the evo
its ok, i understand how you feel :P
i feel unloved too. I got spotted by the cops though :~(
Ha, from what I heard before I bought my Skyline I thought I'd have my own personal police officer and that I'd be pulled over twice a week to look for defects. I've had the car two months now and you know what? Not a single stop or fine. Could be that I drive too slowly to get their attention ... or I'm too fast for them to catch me :(
Black s2 r33 round 4.30pm on tuesday arvo at the lights ftg rd n springvale. Noticed ur led tail lights lookin pretty good. Also ran into a fella at docklands on footacray road in a s2 r34 but sorry mate I forgot what ur user name is. Also had a dark grey r32 gtst following him but din get a chance to chat
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
