who the fk was talking to you?
kitchens that way ---->
stock gunmetal 33 @ highpoint.
Cmon give it a rest, no need for sexist remarks or personal attacks.
I'm sure everyone here has had enough of this like me.
Agree to disagree.
Lets keep it on topic.
Agree to disagree.
+1.
I don't care about your argument before, but remarks like that make me mad. It's attitudes like that that make it so hard for girls who like cars on this and other forums. Absolutely no need to resort to that level of childishness.
End of the day this is the spotted thread, not 'alr33x bitches at everyone for spotting people' thread. Simmer down, it's not a big deal.
+1.
glad you read everything before making a comment and noticing it was edited long ago as everyone seemed to move on, aside from you.
spotted emsta on ironbark road last night at around 5:30?
AH that was u!!!! i think u beeped at me - i was too busy taking that corner :) - i love that road!!!!
spotted wanzi tonight on blackburn rd mt waverley at about 9ish ;) - u wouldnt have seen me - i was hobbling along with my beagle
