because CTP is TAC I called it that because VIC are the only ones to not call it CTP. And in the quote, yes I did say CTP or comprehensive but it should have read TP (Third Party) my mistake for the typo but didn't think it was too hard to figure out. Next time I'll be sure to check my spelling and grammar before I post on a forum :D
Anyways, should probably keep this thread on topic rather than bitch about something that I already admitted ages ago I was wrong about and then gave the proper info afterwards.
spotted a white r34 gtt on the lancefield romsey road than you turned left and so did i and when you turned right i tried to get beside you to say hi but you were already turning. nice car also, looks very clean and you live not that far from me also.
Just saw a dark (probably black) r33 gtr trying to drag me all the way down monash and then on cranbourne narre road... i didnt respond so he got the finger out when he turned into his street... like who tries to drag a N/A in a GTR? fail
lol pretty sad to stick the finger out just because someone doesn't want to go.
Shame on them.
Yep that was me..
Apparently my Ps wernt showing even though they were up
Bald tires on rear (fair enough, already replaced and cleared that)
And I took off a little fast at the lights because my cousin said that there was a hot chick ahead.. again my fault but wasnt anything bad, not even like N/As go fast
he just did me for the tires then and there and told me the other 2 will be in the mail even though he told me to pick one.. so i was like wahhh? then he just like walked off so not sure on whats going to happen hopefully i dont get anything in the mail and it was just a scare as i get off my Ps in 1 month
just for you :bunny:
:) haha cheers man will look better once its not tractor height! what brand are ur l.e.d tails in your dp i want some bad! dont tell me nismo either or ill cry.. i like them just not 1400 worth haha. dont see many nice skylines leaving pettit town anymore... pussys! lol
yeh they are nismo lol i was lucky they came with the car :) im not to fussed bout pettit anymore ive gone past him plenty of times now and he hasnt done anything from my last run in id say im on his good side. besides hes posted in lilydale now
Might have been me, like before 8am? But I get on the ring road there.
It was at about 7.40-45-50, could have been entering or exiting, was just in that part that runs parallel to the fwy. Too bad it was shit traffic and I couldn't catch up to say hello!
Were you in the 34 or the bike in your sig? Yeh I go that way everyday, traffic is always a major pain in the butt on the ring road!! Il keep an eye out next time!!!! :banana:
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
