Saw two white 33 GTS-T's following each other on Reynolds Rd this morning, probably about 8.30ish. Both had SAU stickers, one with a GTR wing, one without.
Wouldn't have seen me as I was in the work car (falcon wagon) lol.
that would have been me and Hekt1c (ric)
hey mate,
nar i work in clayton. the mrs works on hartnett drive next door to that burger joint
that your maron 33? looks tough!
oh cool, yea i work directly opposite your mrs office lol
thanks for the kind words!
parked next to a black/ dark grey 32 gtst with sau stickers at dande bball stadium, nice ride :D
black r32. that was me, thanks :O
You were the chaser with the crazy tyre stretch?
The yellow and red DC2R's were my friends' cars.
yeah chasers mine, lol stretch aint that crazy :D needa get em tyres changed
yeah its lil import section down that end, probably spot you again next wednesday :)
Spotted yellow R34 N/A pulling out of Werribee plaza and was catching up to me :( I gave you a wave but you sped off LOL
Spotted white R34 N/A at Hogans Corner roundabout 2 seconds after that - nice blue parkers mate :blink:
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
