Saw a few P plate r34's at noble maccas the other night, last night saw an r34 "Fast and the furious" mock up there as well. I lolled.
Also had a small chat with a machine of an r32 on the princess last night, blue, apparently has a 2.4l stroked 20. Was thrashing my ears when on boost. Very very very quick.
I was in the white 32 4 dr.
I was there about an hour a go turning left from Springvale onto cheltenham... ...but it's a slip lane so it couldn't have been me getting tagged... ...plus I'd slowed down to look at a black 33 that I thought was Batsi... ...but turned out to be some older Asian guy with two kids in the car...
Spotted two black R34 2 doors yesterday. One at Reading Cinemas in Chirnside Park, bumpers really ratty and cable-tied, rear windscreen covered in JDM gimick stickers, LED tail lights, dildo shift knob, green P Plates. Second was a really tidy GT-T with awesome looking staggered offset matte black wheels, number plates 'NOGTR'. Sounded awesome. I was in the S15 you were staring at.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
