Spotted a white 34 4 door with what looked like SAU stickers near chisholm in frankston wednesday night
That could be my old car, I sold it to a guy in Frankston.
You didnt happen to be at GM today by any chance did you?
Saw one in the car park, although it was plain white nothing like the one in your avatar if thats yours.
Nope, I wasn't. Thats a picture of mine in my avatar.
I thought it was you, but wasn't sure because I didn't know if you had the Cube yet or not. :P
I've had it on the road since October last year. Were you driving the '31?
Oh nice! Nah I wasn't I was in a new R32 I got. It's white with a gunmetal front bar so if you see that it's me. :)
OMG! I see you pretty much every morning in the same spot. I turn right from Dorset Road onto Canterbury Road and you turn right from Canterbury Road onto Dorset Road. Noticed the Bayside Blue R34 GT-R 'VSPEC' that's at the lights at the same time as us every morning?
Spotted W0rp3d outside Supercheap Carrum Downs today :thumbsup:
I thought your car was silver S2? or was it some one else in the black S1 that i was behind before i turned off?
Edited by W0rp3D
V36 coupe (I think black) down Princes Hwy, Berwick last night around 5:10pm - heard there was one in the area, first time I've seen it.
And the same 4-door silver R34 parked outside the United servo on the corner of Hallam-Belgrave and Prinny. Think it's for sale still? Been there for a while.
Haha not every morning now. Just for last I week I was going that way because I was dropping the paper off to my pop on the way to work. I normally just go straight down Canterbury Rd.
Yea I have seen him around the area on Canterbury Rd a few times, I think he lives in Heathmont as I saw him turning out of a side street early one morning the other week. It's a nice car.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
