Spotted a white 34 4 door with what looked like SAU stickers near chisholm in frankston wednesday night
That could be my old car, I sold it to a guy in Frankston.
You didnt happen to be at GM today by any chance did you?
Saw one in the car park, although it was plain white nothing like the one in your avatar if thats yours.
Nope, I wasn't. Thats a picture of mine in my avatar.
I thought it was you, but wasn't sure because I didn't know if you had the Cube yet or not. :P
I've had it on the road since October last year. Were you driving the '31?
Oh nice! Nah I wasn't I was in a new R32 I got. It's white with a gunmetal front bar so if you see that it's me. :)
OMG! I see you pretty much every morning in the same spot. I turn right from Dorset Road onto Canterbury Road and you turn right from Canterbury Road onto Dorset Road. Noticed the Bayside Blue R34 GT-R 'VSPEC' that's at the lights at the same time as us every morning?
Spotted W0rp3d outside Supercheap Carrum Downs today :thumbsup:
I thought your car was silver S2? or was it some one else in the black S1 that i was behind before i turned off?
Edited by W0rp3D
V36 coupe (I think black) down Princes Hwy, Berwick last night around 5:10pm - heard there was one in the area, first time I've seen it.
And the same 4-door silver R34 parked outside the United servo on the corner of Hallam-Belgrave and Prinny. Think it's for sale still? Been there for a while.
Haha not every morning now. Just for last I week I was going that way because I was dropping the paper off to my pop on the way to work. I normally just go straight down Canterbury Rd.
Yea I have seen him around the area on Canterbury Rd a few times, I think he lives in Heathmont as I saw him turning out of a side street early one morning the other week. It's a nice car.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
