Spotted a Black R34 (maybee gtr) going across train lines at Blackburn Station tonight around 10:30-11:00pm heading towards Whitehorse Rd direction.
Lighting conditions were a bit dim missed plates, but it looked like mirror finish paint job. Nice exhaust note too :thumbsup:
I was going in opposite direction.
saw a black r32 with sau stickers on burwood hwy near deakin uni yesterday around 4:30pm, then a few mins later a white r33 gtst ive seen before with a few gauges in the window and a drift cat sticker on the back.
yepp, that glitter red one with carbon bonnet and these massive chromies....
turned out to be my mates' mate ( i reiterate, I DON'T KNOW HIM lol)
and turns out his fiance did a runner 4 days before they were about to get married..wouldn't have happened if his was driving a gtr :P
btw, was out with a couple of lines and a silvia and sti last night
the highlight for me was my mate's new R34 GTR V Spec in bayside blue. When he got the car, took it straight to race pace with N1's and is currently pulling 320rwkw on 18psi.
the car is surprisingly legit, considering the person he bought it off lol, comp test resulted 175psi across all 6 within 4 cranks. Runs TE37 SL's and looks the goods :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
