I don't mind cyclists that are just riding to work or whatever but the groups using the road for recreational riding at peak times annoy me
yeah not much mechanically that's been left stock.. that's why its at a legal ride height with no exterior mods... try to keep a low profile... I even ditched the personalised plates... just make sure to switch it off quick smart when I get pulled over as its got a pretty serious lope at idle
the guys that ride in groups should have to pay for road registration!!!
Yesterday evening around 6PM corner warrigal rd and dandenong rd.
Silver R34 Sedan with some girly stickers, number plates "T34SE"... something like that.
I was in my is200
Edited by iseekool
I was in my is200
She's a friend of mine :P stickers aren't that girly!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
