It is very simple.
Posting details about a car, where you saw it - fine.
Posting details about the owner, where they potentially work, what they look like, rego plates, exact locations etc etc - plain wrong.
If i have to come in here and clean the thread again, whoever has posted off topic shit will get a 14 day ban. Club member or no Club member - you are bound by Forum Rules in the public sections.
Do not push this issue any further, you've all had enough warnings.
End of discussion.
Spotted a silver R34 GTR plates were or similar to ZEGOV on Wedge street, Epping- near my school (SMC).
After a hard 2nd day this term, it really brightend me up :wub: and got my RB senses tingling!
One of the weekdays last week early in the morning (peak hour time 8sih?) a silver R34 4 Door UP my arse I was in my e60 bmw, not sure if he had SAU stickers or not. Seriously dude, if you're on here grow up.. you looked at least 30 it was peak hour drive like a normal person. You dont deserve to drive a 34.. maybe a silvia or something. Even then you struggled to keep up with my e60 .. no chance against my 34 then. wanker.
lol .. There was a white 34 GT with some p plate noob on the moanash the other day, peak hour afternoon he is all over this other p plater in a blue VY commy..the commys cruising along too, but at least with style and not makeing an ass of himself while this 34 is choppin and changing lanes everywhere like a dick and still not getting past, f**k even I kept getting ahead of the idiot in my mazda without effort....i blocked him a couple of times for lols...
Just saw a silver s2 33 dandy bypass was low but with a gay silencer
then a bitchin black 34 with black rims and nice fitment with a twin tip chrome exhaust..looked real clean
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
