looks like i'm getting spotted a lot these days...
hall st? outside a japanese restaurant? i work there.
Thats the one!
I just moved to holmes road 2weeks ago
might come check out the Jap place some time if your open after i finish work
Silver R33 GTR at Shell Petrol Station across the road from The Pines Shopping centre.
Wouldn't it happen to have TE37 Superlaps or similar?
Cos saw that last Sunday on Blackburn Rd when I went to get kebabs.
Yeah I've seen that one too at Blacky Maccas. Very nice and clean if it's the one I'm thinking of.
Couldn't really tell what wheels it had, but from memory, it had a stock looking exhaust and some kinda small toy hanging off the rear bumper.
Saw Odium turning into Wantirna maccas a few minutes ago
Surprised you don't see me more often, and that I don't see him more often :/
Think you noticed me once when I had Alvin's yellow car.
Well, I'm not exactly sure what your car looks like Mr. Birds, Odium's is easy to spot because of the license plate, I've seen him around a fair bit. Nobody will spot me now since I'm under cover in a Honda.
How is the Honda treating you? Come past and show me sometime!
Mine is a silver 33 with D1Rs. When you see it, you'll know.
Yeah it's good, I did a service on it yesterday. It's also got the original exhaust and wheels back on so it doesn't look or sound as stupid as when I first got it. Where would I show you? Do you work nearby? I've been on SAU for quite a while now and I've only been to one meet.. good effort.
I don't recall seeing a car that matches your description, but I will certainly keep an eye out, where abouts do you live?
What wheels did it have on before? Not those stupid chrome wheels everyone likes to put on?
Do you know Terrara Rd?
It had GMax 'Defiant' 18x7.5s, they aren't the worst looking wheels I've ever seen but they aren't my cup of tea, particularly in the size department.
Yeah I know Terrara Rd, my friend lives on Melissa Grove off Terrara not far from the Vermont South shops.
Yeah I love that NASCAR bend around Terrara haha. I'm about 20 seconds from there :)
I thought I was the only one who can't help but put my foot down on that bend, I'll probably be at the petrol station up there tonight filling up.
its hard to spot you adam, since you hardly drive your car.
Adam? Is that Birds' name? Didn't know he had one.
Haha no it's quite normal to assume you're at Talladega dome on that corner. Did you know it before the roundabout at Hanover was put in? Bliss...
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
