canary yellow 34 2 door works on westpool drive hallam. your mate with the silver commie is a dick. whats the point in speeding his tits off.
He works up the road from me. And i know what your saying about speeding . Heap give there car a squirt in westpool dr.
im not gonna lie i get my 33 sideways when its wet, whe i turn into westpool hut i wont go over 60 up there!
https://picasaweb.google.com/lh/photo/W5aG4AovuZBcZCSiK_rJRdMTjNZETYmyPJy0liipFm0?feat=directlink
HKS 26 at Wellington Village or whatever those shops are called in Rowville.
Looks good man :)
Looks good man :)
Saw that today in baysy area on my way home
And a black r32
Navy R34 on Burwood Hwy around 6.30 tonight, think it might have been Auto, maybe kaitoukid I'm not sure.
With bwd hwy there's always a good chance it is me, but not in this case it seems :( . Managed to not leave home all day :D. Also le manualz.
https://picasaweb.go...feat=directlink
Looks good man :)
That was me, Cheers mate, wasn't there long. I always get spotted after it rains and car is dirty, never spotted after a wash and polish etc..- Funny That
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
