red p-plater, silver auto 4 door 34, stopped outside my house next to my car for a few minutes then drove off....dafuq?!
probably going to lock her up behind the gates overnight or the next few weeks lol
Nice Bayside Blue R34 Gtr Vspec2 through Doncaster around 5pm last night. Sounded rather loud.
Being a R32 tragic for their aus motorsport history I do see the appeal in a modded R34 when I see one in the flesh. I think if I had a R34 though, i would have to mod it to within a inch of it's high reving gt life... whereas I cant wait for the excuse to put a 3.4 small turbo road grunter in the R32.
[THR34T] overtaking me with a bit of sutututututu on springvale rd around 8-8:30
Blue r34 kingsway glenny, had SAU sticker around 10:00
What colour is your 34? There are couple at Monash that I see semi regularly. There is also a silver 33 4-door whose owner I work with and a purple (same purple as my car!) S14 S1 whose owner I also work with :).
Black with white SSRs :)
Bahaha skyline ghosts of Monash
Edited by kaitoukid
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
