red p-plater, silver auto 4 door 34, stopped outside my house next to my car for a few minutes then drove off....dafuq?!
probably going to lock her up behind the gates overnight or the next few weeks lol
Nice Bayside Blue R34 Gtr Vspec2 through Doncaster around 5pm last night. Sounded rather loud.
Being a R32 tragic for their aus motorsport history I do see the appeal in a modded R34 when I see one in the flesh. I think if I had a R34 though, i would have to mod it to within a inch of it's high reving gt life... whereas I cant wait for the excuse to put a 3.4 small turbo road grunter in the R32.
[THR34T] overtaking me with a bit of sutututututu on springvale rd around 8-8:30
Blue r34 kingsway glenny, had SAU sticker around 10:00
What colour is your 34? There are couple at Monash that I see semi regularly. There is also a silver 33 4-door whose owner I work with and a purple (same purple as my car!) S14 S1 whose owner I also work with :).
Black with white SSRs :)
Bahaha skyline ghosts of Monash
Edited by kaitoukid
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
