Unfortunately I spotted this idiot on Facebook (Victorian Plates). Ripping skids in his n/a R33. Stupid kids. It's people like this that give us a bad name. https://www.facebook.com/photo.php?v=488278684598545
Got me all excited about naming and shaming.
Then the link doesnt work, im shattered dude.
Blue 34 Springy Rd, just past the monash, bonnet up... if I wasn't dying and going the other way, I would've stopped... although only use if it was just a jump haha. Hope you got her back up and running lol. Just earlier... so 3ish.
Black 34 sedan green p plates this morning around 9:45 on springvale rd, I was in the coupe :P. Sounded nice.
On Saturday night around 830pm Was next to a black or dark blue r34 on Springvale road across the road from the kebab joint. I hit a little boost and opened the gate up !
You had to turn left on prinny hwy and as you went past you show off your gate too sounded awesome ! Sorry I had mommy in the car or else I would chased you for a run. I was in a black r34
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
