awww thanks! :) Was it up in upwey? or maybe rowville :)
haha no probs! guessing you sold the 34? :/ you were parked in front of karoo primary, I live just down the road, literally on karoo road :P
Yup the white r34 is gone, didnt need an r34 and a gtr :P, i think i saw you yesterday drive down karoo roar (you drove past a white evo and a big red holden crewman)
ahh fair enough, that's true. :P hmm I think I did but I didn't realize it! I've been seeing your mates white Evo quite regularly now on Karoo, gave a mutual thumbs up a few weeks ago. Defs stop by next time you see my car, i'm usually parked on the street (Napolean side of karoo). :D
To the black 34 GT-T number plates YIO-xxx, who thinks it's hectic to be speeding 40+, tailsliding every corner and trying to coerce other cars into dragging you on freshly wet Warrigul Rd at 1am - my car is faster than yours, there's a time and a place to prove it, and I hope you and your Range Rover-driving tool of a mate kill yourselves alone before you take someone else out with you. Do not want.
+1
Not your colour Alvin... Yours is Yellow... I'm talking about an orange/yellow colour (not sure if factory or custom... if custom, someone needs a slap)
Edit: It was actually kinda similar to this colour... But on a 4-door its just a giant slab of orangeness... and 700% less awesome than this car ;)
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
