awww thanks! :) Was it up in upwey? or maybe rowville :)
haha no probs! guessing you sold the 34? :/ you were parked in front of karoo primary, I live just down the road, literally on karoo road :P
Yup the white r34 is gone, didnt need an r34 and a gtr :P, i think i saw you yesterday drive down karoo roar (you drove past a white evo and a big red holden crewman)
ahh fair enough, that's true. :P hmm I think I did but I didn't realize it! I've been seeing your mates white Evo quite regularly now on Karoo, gave a mutual thumbs up a few weeks ago. Defs stop by next time you see my car, i'm usually parked on the street (Napolean side of karoo). :D
To the black 34 GT-T number plates YIO-xxx, who thinks it's hectic to be speeding 40+, tailsliding every corner and trying to coerce other cars into dragging you on freshly wet Warrigul Rd at 1am - my car is faster than yours, there's a time and a place to prove it, and I hope you and your Range Rover-driving tool of a mate kill yourselves alone before you take someone else out with you. Do not want.
+1
Not your colour Alvin... Yours is Yellow... I'm talking about an orange/yellow colour (not sure if factory or custom... if custom, someone needs a slap)
Edit: It was actually kinda similar to this colour... But on a 4-door its just a giant slab of orangeness... and 700% less awesome than this car ;)
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
