Road And Track Comparison. Gt-r Vs Z06 Vs 911 Turbo
Quote of the thread
" something fishy is going on here. I'd like to see some more comparisons.
I'm sure it's an awesome car and all..... but seriously.... "
got denial ??
EDIT : look at post # 53 is that the monaroCountry of SAU?? hahaha give up champ the car is a god.
Edited by Zoggy
Straightline vs Corners. GTR and Porsche never claim to be straightline speed demons but Tarmac, twisty windy thrillers, Where the corrvette is sold as the equal to these vehicles when it clearly isn't designed for what it is marketed for. Another example springs to mind the chrysler cross fire.
all hail skyline!
id rather have a car i could drive/corners then just plant it and and watch the speedo rise
all in all the gtr does seem to be the perfect compromise, and afterall it isnt that slow in a straight line anyway!
The video was pretty boring, no real action.
But the PDF files really had some interesting data in there.
Couldn't be stuffed reading 50 pages of dribble on a forum though.
Although one dude sayiong the 09' Corvette should/will have more horse power...blah blah....???
STILL doesn't get it..... :cool:
Hang on guys... but if the corvette was on a roll.... and if it had different tires, and if it was a different track, and if the gtr wasn't running an Awd system, oh oh then the corvette would win...
You forgot to mention that the GT-R was cheating with turbos.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
