Hi guys,
Busy few months indeed, it's been a while since we posted some new photos and updates on the development and race preparation of our R35 GTR for Team Donut King.
Since arriving in Sydney back in January we have been in a mad rush to get the car ready to race in Targa Tasmania, so understandably the worklist was long and we have been working around the clock to get the car ready and we are pleased with its progress.
We have been working closely with Mines Japan and as a result the car is now sporting a list of items fresh from the Mines catalouge and we are delighted to announce that we are now stocking a range of R35 GTR parts from Aero and aesthetic bits and pieces to their impressive Silence-VX Titan Pro II Titanium Exhaust system and VX-Rom Engine Management. Many of their newly developed parts have already made it onto the car, like the Front Brake Kit and VX-RPM - A few other items like the ESTA (SACHS) Full Spec Suspension II Package are waiting to be installed.
So without further delay, here are some progress pics - Hope you guys enjoy.
Mines' new mammoth 400mm Front Brake Rotor Upgrade arrived last week and is currently sitting on our workshop floor waiting to be fitted once the car returns from circuit testing:
Here's how they look fitted up:
The work of art that is the Mines' Silence-VX Pro Titan II Exhaust System - Full Titanium (As it should be!) - Now fitted up
As some of you already know, the car is now fully caged and the interior really looks the part now! The seats were removed and replaced with Sparco Pro 2000 buckets for racing, along with HPI racing harnesses. The cage is a full 6-point setup, from Bond Rollbars.
Further race preparation - Interior door trims have been replaced - Bare essentials only :(
This is the result of some agressive circuit testing on the 20" Dunlops
We now have sets of the RE070R's in stock - The price on them will make you fall over.
Spare set ready for Targa
Thanks to all of you who have showed your support for the car and we look forward to seeing its potential released at Targa.
More updates to come as we have time.
For anyone interested in the other Mines parts we have available for R35, we invite you to browse our website using the below URL:
http://justjap.com/store/manufacturers.php?manufacturerid=60
Cheers,
Steve
This is the result of some agressive circuit testing on the R35's factory rubber!
Obviously they've tested something different because the used tyre pics are neither factory bridgestone's or factory dunlops... The tread pattern is something different.
:D
Does the rotor upgrade need or come with caliper adaptors, my 35 should be hitting the dock soon :D
nice! what colour did you buy? and for road or race?
hahah i shouldnt have, but its april fools day and i just couldnt resist :D
the only 35 i have is in gt5p and its gunmetal grey, no real 35 for atleast 5 years for me :D
back on topic, i like those door skins who did those?
Edited by 2630GTS
So the Mines exhaust complies with Targa Regs? I thought it had to be std diameter or something? Awesome work on going to town on the R35. I hope Targa goes well fo you guys! :D
Also, do those rotors happen to have RDD etched onto them anywhere? Also, interested to hear your feedback on the Sachs shocks and whether they are supple enough for an event like Targa?!?!
Nah Bris, the rules have been relaxed..... for instance, we can now go to 3" for the 34 (but haven't, decided to leave well-enough alone).
Juat Jap, re the rotors. Can you let me know if Mines are sourcing their rotors from RDD these days? Is RDD etched on the rotor anywhere. Im curious as looking at the direction of the slots and the direction of the vanes, most manufacturers avoid that combination in the quest for durability?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
