If you can run the 1.1mm gap without it missing then do it. The bigger gap the better. People only reduce the gap when they are running large boost or have old, weak coils that can't provide a strong enough spark
That's true, only reduce gap if you have to.
NGK BKR6EYA. = 0.8mm
I was running these on 10psi with stock ECU. No Problems.
Installed an SAFC 2 and my Tuner gapped them down to 0.7mm due to old Stock Coils. No Problems.
NGK BKR6EYA-11 = 1.1mm
I will go back up to 1.1mm soon as I just bought some Brand New Stock Coils.
This will be interesting...
That's what I thought.. I will try the 1.1mm gap an see how I go. It only has 140k on the engine so coils might be fine.
Is 1.1mm and 0.8mm the only 2 gaps I can run or should I try lower the gap in 0.1mm increments like as in if 1.1mm doesn't work maybe try 1mm then 0.9 then 0.8 or is that pointless? I'm new to the whole boost scene so excuse my lack of knowledge haha appreciate everyone's help :)
If they are the original coils at 140kms then they will probably be getting a bit weak.
And yes, you can just drop the gap by 0.1mm increments until it doesn't miss
If you want cheap BCPR6ES, get them off eBay
Just buy more than 12 at a time and it works out pretty sweet, $2.90 each delivered
http://www.ebay.com.au/itm/NGK-spark-plug-BCPR6-ES-plugs-BCPR6ES-tradeprice-2330-/330828510503?pt=AU_Car_Parts_Accessories&hash=item4d06ea7527
I just ordered 24 lol, works out to be $2.81 each.. :)
Well the 1.1mm gap works fine. Revs sooo much smoother now. Coils must be good :D Old plugs had a little miss before it revved. Doesnt miss at all during idle or rev. Have no driven it yet to test them under load but all seems fine. Thanks everyone for your help
  • 7 years later...
I've checked alot of places and I can't seem to find BCPR6ES spark plugs with 0.8mm gap I can only find 1.1mm and super cheap say (after rego checko) they are not a right fit for the rb25. After alot of searching and doing my head in I found BCPR6ES with a 0.9mm gap from justjap so that's what I went with... ?‍♂️ Stock rb25
Hmmm. You just set the gap to whatever you want with a very cheap tool.
I use those plugs with 1.1 gap and have zero issues. Drop gap if your coils are shit, otherwise leave at 1.1
So why so hard finding info ? Gapping copper/nickel and platinum plugs is trivial. Iridiums are the only ones you've really got to be careful with. In NGK if it has no - prefix at the end it is like this-
# heat range.
Copper/nickel plugs, the bcpr#es is pregapped to 0.9mm / 36 thou, there is no 0.8mm gap in bcpr#es coppers.
Platinum plugs BCPR#EP and Iridium plugs BCPR#EIX, are pregapped to 0.8mm / 32 thou.
A -11 at the end indicates an 1.1mm / 44 thou gap as an option, available in all of these plugs.
15 hours ago, Kiza said:
I've checked alot of places and I can't seem to find BCPR6ES spark plugs with 0.8mm gap I can only find 1.1mm and super cheap say (after rego checko) they are not a right fit for the rb25. After alot of searching and doing my head in I found BCPR6ES with a 0.9mm gap from justjap so that's what I went with... ?‍♂️Stock rb25
Also 5 is stock NGK heat range for RB25, 6 for RB26.
Probably why Repco / Supercrap say it's the wrong plug too.
  • Thanks 1
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
