RB26DETT or 2JZ
263 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 124
Posted Images
Interesting read...
My main aim for the car is 90% road and 10% Drag strip (no drift or circut)
I have spoken to a few tuners and they all said "Nissan build the best 4cyl and Toyota build the best 6cyl"
Whether I get a GTR or a Supra im just going to do all the bolt on mods to geting going fast. I have seen some 2JZ's with the HKS T04Z and they are pumping 500+ rw/hp on stock internals! Now i have yet to hear of a stock RB26 with a T04Z even coming close to that... Have any of you?
That black Supra THNKB4 was tuned by Adam at J.E.M and i have seen this thing on the dyno and it is an animal
http://justenginemanagement.com/Michaels_supra.html
Yet another animal Supra:
http://justenginemanagement.com/finkb4.html
Then again... this looks like sex on wheels too!
http://justenginemanagement.com/wild_gtr.html
So damn hard to choose... i think the best way is to take my time... not to rush.. when I find that Supra/GTR that wins me over... ill just buy it!
Edited by QRI05E
ive said this a million times...
Both engines cost the same to get 500hp ffs
they both handle more than 500hp with stock internals so easily
never seen a T04z equipped gtr makin 500rwhp?? not even close?? dude.. im makin 410hp with a pair of hi flowed twins... no big deal. a T04z will make a shit load more then that.. even a GT35R equipped GTR makes more then that
In sayin that, so will a 2JZ. The 2JZ will also spool the turbo up quicker makin more torque sooner than the GTR, but it doesnt rev as high meanin once it comes into stride u havent got all that much time to play with it. 7000rpm limit compared to 8500 for a GTR or if ur game.. add another 500rpm to each.
To top it off the 2jz is also more reliable @ higher hp outputs. That is probably due to the 2jz being built slightly stronger, but it also doesnt rev as high or hard so it will naturally be more reliable.
Now the problem with a Rwd car that has massive midrange torque as well as a strong top end is that it only has 2 wheels to transfer all that extra torque and power = excessive wheel spin. Of course tyre selection can reduce this, But a GTR which will produce less torque down low doesnt have this problem.
Having a higher RPM limit also makes the power more usable in the sense that instead of having 500nm @ 2000rpm which isnt as comfy as u think, it makes the same 500nm but @ 4000rpm. Torque isnt delivered as brutal because 4000rpm might be 40km/h instead of 20km/h. To add to that is its 4wd system allowing the brutal transaction to be delivered just as brutally to 4 wheels using the same tyre selection.
BUT!!!!!!!!!! a 2JZ in a GTR using a 4WD system would be optimal.
Tell the oodles of people that have had their RB26's die in a nice fashion @ 500hp (or less) that you think its fine.
Im sure they will all believe you and it will make them feel 10 times better about thier rebuild
Reality is though, they dont last. The sooner you understand this the better off your posts will be for this forum.
So many people have lunched them for many varying reasons, stock part failures and so on where the 2JZ has far far less documented problems (read:basically none) at that level.
When he said close/t04z etc, he means in terms of not shitting itself at some point down the line, which just about every RB26 would making 500hp.
ummmmmmmm... ooookkkkkaayyyy :P .
have a look on supra forums mate. im sure they could shed some light on this issue
Don't seem to be very easy to go quick in on the drags without some tyre changing at the track?
At least these are what times the WA cars run. Decent, just not what I was expecting with all the hype?
http://www.supraforums.com.au/forum/showthread.php?t=40790
most supras are built over here for dyno comps, they can be set up to go quick on the quater easy, just need to look to the US for how to do it. that purple supra from millenium ran 10.0 with a 2.2 60ft, when that gets sorta its easily gonna run mid 9's, and i think hes on radials aswell, not slicks, could be wrong on that htough
Don't know how easy it is? Seems like it's not as easy as a gtr to run 11's at least?
The standard supra gearbox seems to have less strength than the gtr gearbox too.
Alot more to a car than just it's engine is the moral of the story I think.
i think i disagree with the box as well.. ive always known the 6 speeder to be as bullet proof as its engine.. '
If th engine was the decider on what was a better car, then the supra would win hands down. But like Rev210 said, theres alot more to a car than an engine..
because of this, the GTR always wins hands down.. just look @ its track record around the entire world :P
yeah only issues with supra gearboxes are the W58's (non turbo) when people turbo there car. the supra box is tougher than any skyline box (exclusing R35 obviouslym as its an unknown) bar the 34 GTR, because its the same box.
never heard of the GTR being king of the streets but yes brakes are better and 4wd obviously. supras are better value for money because they maintained the same design while the skyline spanned 3. that said a 2001-2002 manual RZ would be getting up there with cheap GTRs in terms of price, since GTRs have come down so much
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
