I recently got my car tuned with 'response' in mind.
I have -7's, ID2000's on pump 98 and stock internals, and this was the result:
1476343_10153636999910301_502255709_n.jp
Does this graph represent a "responsive" engine? Certainly feels responsive, as in there is very little lag when going full tilt.
Obviously it has a long way to go as far as HP is concerned, but would that response be sacrificed if boost pressure was increased?
It all depends on the tuner. I get full boost by around 3900RPM for my 320KW. Though i dont have stock internals. Is there a reason you got ID2000? Large injectors for the turbos you are running. Also what AFM are you running? that to me looks like stock AFM maxing out.
Running ID2000's because I will eventually run e85, just ran out of funds to flexfuel setup. Everything else is ready to go though, twin 044's and surge tank etc.
As for AFM's, I switched from a vipec to a haltech platinum pro, so it shouldn't be relying on AFM's as far as I know.
Interesting. Could possibly just be the age of the motor.
Edited by Anfanee
What would you be expecting? We did ask for a reliable tune. When I decide to rebuild I will chasing HP but at this stage I want it to last as long as possible.
Wouldn't know without looking at the actual health of the engine. Your tuner would know what they are doing. Best to keep it as safe as possible. My tune isn't overly "Safe" its a bit agressive but i have had a ground up rebuild.
That is a nice curve though. From what i've seen most cars run around the 270-290 mark that are still stock internals.
Honestly until you even think about doing internals i wouldn't put in on E85. Has the motor been rebuilt previously? if not 20 years is a long time worth of thrashing haha.
I should have taken some photos of what my motor did to itself...
Edit: as zebra said. It's fine. Im pushing 21PSI through mine...
Edited by Anfanee
Shit that's good for standard actuators. I can't believe they still hold boost that well.
it's more the way the cams are set, making better use of the air it gets meaning the turbos don't have to working as had
a good quality boost controller doesn't hurt either
Haha,don't know,hoping to fix it with next tune,that tune just then was a lazy tune I think,took him an hour
what mods have you got done ?, cause yeah that's not great at all, what boost is that ?
cam gears ? if not get some
  • Like 1
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
