  On 18/02/2014 at 4:57 AM, XKLABA said:
That does make helping harder, where are you located
What you might have to do is rip off one of the cam covers and get the part number off the end of the cam cause if their not poncams but full aftermarket then poncams may not be "boltin" any more in which case you may as well go the 260 x 10.8 procam or better yet the unigroup cams
Located in Warrick Farm area, between Cabra and Livo, hmm, i'm not very confident in doing that myself xD might need some help.
I didn't intend to get involved in the usual FIP section pissing contest.....just to make the point that if your tuner says they "tuned for response" without changing anything mechanically you better find a tuner who isn't talking shit.
Jimmy, I was listing mechanical factors that affect response; once the mods have started most people forget how early the standard setup gets on boost. I built the stagea deliberately for response which is why it has standard zorst manifold, standard cams, standard head, small turbo and 3 litre bottom end. And it makes 18psi by 3200 rpm
If I wanted more response I would add cam gear (as I have on the race car), it can bring on boost a few hundred revs sooner at the cost of top end power. But frankly it comes on hard enough early enough to empty the fuel tank quickly.
For a race car I would say it is a very different concern. Full boost at 5 or even 5.5 is adequate especially if you have short gears and a standard or raised rev limit.
  • Like 1
  On 18/02/2014 at 10:08 AM, zebra said:
You can't because it wont sounds nice
Not that I'm sure that anyone would be able to hear the difference.....but if all you are worried about is the sound, you must also be the type that buys cars on how many cup holders it has!
Shut up mate, I do that, my new car has 10 cup holders ?
For me,
Bottom end:
Standard rb26 crank, nitrided, chamfered oil holes, Standard rods resized and shot peened,
Hypertectic pistons, id have to look into brands before deciding, but i do not believe forged slugs are required, pistons to suit 10.5:1 comp with valve relief's, steel comp rings, low tension oil rings, restrictors fitted to oil feeds and head/block returns drilled out
Head: stock valves, heavy springs, cams 260/262 10.5 lift dialed @106/110, a good throat job and trim valve guides, head decked to suit chosen pistons,
Turbo and pipes: small diameter high mount turbo manifold, hks 3037s, 50mm gate with 2inch open screamer, 3 inch dump, no cat or mufflers, strait to the rear
2.5inch stainless cooler pipes to replacement factory sized cooler, water/meth nozzle directly before inlet to plenum,
Id run 18-20psi, i believe a good tuner could really lean on this combo and make a rediculasly responsive weapon that packs a punch
Hmm, first question to get a post out of me in a while lol
Lets not forget the key point to making response as to a revy engine.
Light recipricating weight in the engine.
Lightest pistons and rods, crankshaft and flywheel.
Gearing helps to enhance the free rev nature when on power.
Dont get too carried away though, a clutch dump start can lead to a serious bog down on launch. :)
Turbos, cams etc work with on power driving response as does a smaller volume intercooler etc.
Edited by GTRPSI
You can look at this another way by thinking what Nissan would have done if they wanted road car like characteristics in a GTR . I think the logical solution is to start with a Neo 25T Stag engine and build it up to a level rather than trying to convince RB26 to do what it wasn't intended to . Don't hate me people but I consider an RB26 a dumb road engine in some ways because Nissan didn't put any of the smarts into making it a nice road car engine . It was intended to be a bit of a hero drive because the basis was for a road race GT car not an all round street car .
The Neo has a higher CR and the last big bore (86) turbo RB revision of chamber and piston crown shape . The whole inlet exhaust and turbo systems are designed to make good part throttle torque which is what any successful ROAD car formula HAS to be based around .
This is not to say you can't build a pretty healthy RB25T that still retains good road car characteristics . Neo head I reckon better basis than RB26 because of the chamber redesign and the two stage inlet cam phasing . On the other side of the coing the RB26 inlet system is a better performance design and better suits a GTRs air plumbing .
Production 25s always had single turbos and they have developed to the stage that singles can be pretty good nowdays .
Consider this clean sheet approach .
Neo Stag 4WD RB25DET .
Graft RB26 inlet manifold onto Neo head .
Bore to 1 OS to have similar capacity .
Standard exhaust manifold .
GT30 based turbo ie 0.82 AR IW 3076HTA .
Don't think 300-320 RWKW is an unreasonable expectation and non of this stuff has GTR/RB26 "tax" attached . Legally no capacity or rated power issue and Neo is emissions approved engine in Australia . You lose all the TT complexity and service bastardisation you have with the hot side of a factory RB26 .
I reckon this combination would give a stdish GTR in the same shell ie 32/33/34 a bloody quick hurry up and be better to drive in Camry mode .
A .
  • Like 1
  On 17/02/2014 at 1:30 AM, J said:
Part numbers they have listed in Ebay are for tybe B cams. which are 260 degree 9.15 lift.
http://www.tomei-p.co.jp/_2003web-catalogue/e070_cam_RB26.html
I sent tomei an email last week about those cams to check out what was the go with them and they replied that they were legit and we're a small special order item to some dealers
This is about the ex 270 9.15 lift right? Got told that they don't make them anymore, thats why they're not listed anymore.
Thanks log in. :)
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
