haha not required thanks, I know which side of the steering wheel to grab. its "keeping an engine alive without something wierd happening to it" skill I desperately need.
brad - very little progress this weekend - the rear cradle is ready and mark fitted up some of the bits but we need to do some welding on those wierd little bushes for the upper control arms at the hub (weld the crush tube to the hub to solid mount it), and press out the tie rod ball joints so we can replace it with some sort of new bush too (probably ally).
spent the day putting the motor in my car, including that wonderful moment when I realised the new crank had no spigot bush (lucky mark's race motor was out, I stole his when he wasn't looking). did all the dirty lying on the ground work today and will finish off all the clean top of the engine glory work this week. then back to the nugget, cage in mark's new car and getting his filthy gas burner running, all in 6 weeks.
and to catch up on the last couple of pages:
chris - we have obtained some remote canister g4 test shocks and are going to give them a go. they need new springs at a minimum and we will probably get the shocks checked and gassed up properly before we use them seriously. right now they are just holding the car up. what are you running if not the Teins?
stu - I've never run with a bias valve before and this car has standard rear brakes and g4 fronts (ie very similar split to standard). But all skylines with stockish setups I've driven lock the rears first so I figured considering how cheap the valve is compared to a full bias bar pedal box that we better give it a go. will be interesting to see how useful it turns out to be.
yer Duncan the teins are under the old girl, thought i had been kissed on the end of the damper by the good luck fairy when i seen these just sitting there....all alone...with no car to put them in! Anyone want a set of good remote canister tein circuit masters for a R33 GTR i am traveling back to Oz this weekend.
Sorry for the possible silly question but when making the rollcages how do u go about accessing the pipework near the roof etc to weld it around completely? ive seen guys cut panels out the floor, is this normal method or is there another way? i have all glass in the car too which obviously isnt going to help i assume.
benm Posted Today, 03:39 AM
Tack it up then drop the main hoop down through the floor a couple of inches and weld up the top loop properly
That's how we did mine but another way, if for some reason ya can't hole saw a hole through like if the sill is in the way or something there is another way that I've seen which works. Cut the main hoop shorter, weld around the top and then build boxes and sit the main hoop on top of them. Dosen't look as neat though.
thats how mine was done
Wait, stop, don't do it! Cut holes in the floor that is.
Absolutely not need to cut holes. Best approach is to make up a triangular platform in the corner behind each door to bring it up to level with the step. Tak the step, make your bar, cut the taks to drop the step and the bar, do your welding and put the step back up and weld it all. All good cages I have seen use this method. allows you to properly weld the main hoop without having to move it too far forward or back.
I personally use the through the floor method.
If your good with the bender you can get the hoop bases close enough to the body and the step so you can actually weld the bar to the step all the way up. Looking that the 34 thats what they seem to have planned.
Merli whoever did that front leg did a pretty good job. Its nice and snug to the pillar. Takes a lot of time and patience to get them that close.
Edited by Risking
Yeah that's what we had done, plated to spread the load and welded the length of the tube to it. This is about the best pic I can find;
Yep, I was blown away with the attention to detail. The entire cage is beautifully snug against all the pillars and roof.
Peter Muir from Bondy did it for me... Got the introduction and hookup from Steve Thatcher, so I think that helped with the perfectionist result of the job :P
Those front legs had 6 bends each to get them to sit that close... Amazing anal-ness that would rival my own ;)
Alan Smith tells me you guys are good mates :) Tell him to get off his arse and buy Ric Shaw's FD3S...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
