Can you tell me how long my piece of string should be?
motor condition, type of use/abuse all move the goal posts. Why would you want to anyway, a stock R33 has no real power in the top end anyway.
Cos, you could R+D it and then tell everyone how long it lasted............
personally if it were my 25 I would not be revving it past 6500, but it's your engine so up to you. sure it will survive 7000 a few times, hell it could survive 8,000 a few times... but for how long?
lol, this is a thread full of comedians.
Find out where the power peaks and drops off, and set the rev limit there.
If your peak power is beyond 7,000rpm, then you have a massive turbo that requires a built engine anyway.
Your shift point shouldn't be at peak power, it should be where you have got an optimal area under the curve. I aim for ~500rpm after peak power...
the idea of rev limiters and tachometer shift lights go hand in hand, when you change gears you want the engine rpm to fall back right into the middle of the power/torque area when the motor is just at its peak power levels...(where the hp and trq curves meet/intersect or are closest to each other...within reason of course)
for example the dyno sheet below for my gts4
the sweet spot is 5150rpm, theoretically i would want the engine rpms when changing up to drop back to anywhere between
4200 and 5300 rpm.
for example if a rb engine bolted to a manual box drops 1100 rpm between 2nd gear to 3rd gear the ideal shift time would be 5000 to 5500 rpm
to get the maximum amount of power when accelerating. this is a rb3026det freshly rebuilt for drift, mildly tuned @8psi so there's not really any call to go over 7000 rpm, and even then you only want to go past 6000 once in top gear.
Edited by nizmonut
question
can the stock engine rev past 7,000 rpm safely??
-stock internals, stock airflow etc
- and assuming your not limited
More to the point - stock airflow (which one assumes is turbo/IC and so on)
Absolutely useless and pointless
Either way, luck of the draw over the limit, might last a while, might last a bit longer, might not
Simple really.
One of my first Power FC tunes on the highflow turbo i had,the rev limit was set at 7500rpm.
Was like this for about 8 months and saw 7500rpm a number of times,though was not held there for any more than about 3 secs.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
