I too am keen to hear this, how is it to drive?
speaking of RB20E, i one had a skyline with an RB20ET, i bought it thinking it was a RB30DET cause it looked like one under the bonnet,
Didnt drive that bad really until the auto decided to start slipping and then found out it was running 1 bar of boost. lol..
You actually broke a spanner? What was it plastic! Lol surely you would round the sump nut before breaking either of those. Also a socket doesn't have threads haha.
Remember this rule, lefty loosie righty tighty and you can't go wrong.
Those do sound like cheap tools...
Sougi is done and dusted kids, don't bother asking me for it :)
Still have some bottles of M5000 left but can't be assed posting interstate...if you live local in Melbourne you can come get it off me, otherwise go to hell and wait for Syn 6000 to be released!
Lol yeah they were pretty cheap, I thought it was on too tight so ended up using my foot to push the spanner and try and undo the bolt but it snapped and I nearly sliced my foot open... Probably shouldn't be telling you all this, I'll just get teased lol
Not gonna lie to you mate, for various reasons it takes me fking AGES to do oil changes too. Not so much because I'm newb at it (done plenty of times) but because I'm simply retarded.
FWIW :P
I'm just compulsively clean...gotta clean all the crap the old filter spills out, wipe the sump, get every last drop of old oil out...have that oil level at exactly the same lol.
buy one of the $16 bottes of gw from supercheap
drain the old stuff
put in the cheap stuff
run it again
put the dirty stuff away
drain the cheap stuff
put the good stuff in and keep the cheap stuff for another clean
How do you guys get every last nasty drop out?
Undo sump plug, go have beer, cup-of-tea, have a chillax, change filter etc... Then do up plug and keep going.
Do you go so far as tilting your car and dry cranking the motor for a second??
Prolly would skip that step.
Do you use a flushing oil?
Some people swear by it, but it's not necessary if you're using decent oil and changing it regularly. Not all carbon deposits in the engine are the "devil", any deposits for example smoothing out imperfections in the cylinder lining will be removed, which will subtract from engine performance and longevity.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
