I would rather use a better oil than the factory stuff as i have had work done to the motor and want it to last a long time. The royal purple is the best i have used so far but getting it were i live is almost impossible unless i mail order. I have tried synx 3000 ( before the car was rebuilt ) and also tried Motul 4100? didnt seem to like the lower oil pressure from that one. was just curious as it would be nice just to go down the shops and find something. Does anyone have any comments on the Castrol edge 5w40?
chat to whoever built the motor and ask them what oil they use
Stock rb30 = coles motor oil changed every 50 000km's and it still wont die....
ARTZ, the HPR will be fine, i used the old HPR for years and years at double factory power and when i pulled the motor apart it was immaculate. I cant see the new HPR being anything but better again. But then again I'm a big Penrite fan so i might be a little biased.
well I wouldnt call that biased, I would call that tried and tested ... I'll stick wih it :cheers:
Just out of curiosity ,whats in ya gearbox..
Given that the RB26/25/20 is an old motor(s) designed in the 1980's when oil technology was nothing like what we have today, I see no reason why a good quality mineral oil of the correct weight and changed regularly (5000km) will not provide good long term protection for an RB motor.
However as soon as you change turbos (specificaly roller/ball bearing) you are adding a much newer component built and designed around much newer/better oil technology. At this point i would say yes you do need to move on to modern semi-synth/full synth oils.
But as I change oil at <5000km service intervals, I figure the oil doesn't get to the point of breaking down and failing to provide proper protection. As such I dont see any need to buy top priced oils which are developed to work better over longer periods of time.
Of course if you are servicing something newer i.e. a VQ series motor then this pretty much goes out the window.
The thing is, back in the 1980s no one was making 300+rwkw out of 100% standard RB bottom ends, if you tried to with 80s spec mineral oil theres a pretty good chance it wouldn't last long. For a standard car, sure anything thats costs more than $1/L will probably be fine if changed regularly, but if your near the limits of a standard motor or on the track a lot decent oil does help it last longer.
I'd like to throw an analogy your way and see what you think. You were born/built before the 90's (I'm guessing), so would you suffice living on technology available in the 80's or pertain to the use of modern technologies to further your lifespan? Granted I'm drawing a bow with comparing a living organism to a machine, but the principles of making things last are the same. We're living longer than ever before and that's because of advancements in food/safety/medical/pollution technologies + some help from our friend evolution. The same can be applied to engines, within reason. Remember that oils are designed for engines, not the other way around. There have been a lot of advancements in engine designs, but the bread and butter workings of the internal combustion engine are still the same - piston slides up and down a cylinder bore, turning a crank bathed in oil.
An RB will run fine on the oils that were out at the time, but it can certainly run better and last longer on a better oil - many additives only found in modern oils are designed to promote longevity and reduce friction. Ask any Sougi users (well, ex-Sougi users) for their opinions on an average oil compared to this top drop and they will tell you which comes out on top, whether it is worth spending $60+ on a ~20 year old engine.
To draw a better analogy, I consider ethanol mix petrols to be a technology of engines - not unlike advancements in oil technology - the result is a higher octane combustion mix, which allows an RB to produce more power and run cooler than it was ever originally designed to on 98 (was 98 even commercially available back then?).
For over the last 5 years ive been religious to using Castrol Edge in my evos. Since owning a skyline and being apart of this forum, reading peoples "opinions" about oils... Castrol apparently is not as good as it used to be especially since BP brought them ad boosted there marketing and decreased the quality of the product..... Apparently....
So I went out and brought some AMSOIL 20w-50 Race Oil.... Its great stuff!! Its 100% Synthetic not "Fully Synthetic" as Castrol states. There is a difference.
But.... My car isnt running at its best and I think the oil might be wearing a little quicker than normal.
So I may of wasted my money im not sure. the price difference isnt to bad ($90 for 5L)
Being 100% Syn, its alot lighter or watery than the equivalent branded "fully Syn"
Im not worried about the 20w as it dosnt get cold enough in Australia to need a really low weight oil like 0w or even 5w
But im running a BB turbo and I do like boosting it most days, so its important to me to have a high temp oil like 50.
Basically to reply yo you... is Castrol alright? well its ok. ive never had a prob with it. but there is better stuff. The question is do you need to spend more $$$ on better quality oil?
Just make sure the weights are up to what your car needs what ever brand. I might give Castrol another go next change.
Edited by HYBR3D
Hi Every1,
Due for an oil change and was ready to buy some royal purple 10w40 for my 34 GTR (completely stock with 83k on the clock).
After reading through some of this thread, not quite sure if the viscosity i've chosen is the best choice?
Car is mainly just a weekend toy and wont be seeing any track time.
Any advice, info or confirmation would be appreciated.
Cheers in advance.
Edited by iwanta34gtr
lol wut? castrol edge is castrol edge. no changes there apart from the packaging for 2012
there is, but becasue something is 100% syn doesn't actually make it better. a mineral content has its advantages as well as it's disadvantages
for you to notice this,:
how is it driven?
how old is the oil?
what are you actually noticing?
have you tested the oil?
what does the oil look / smell like?
you do realise there is a lot more to cold oil weights than ambient temperature yes?
Hi Every1,
Cheers in advance.
for a weekend toy that doesn't see track or a long time on the limiter i think 10w40 is definitely the right choice for an 83000 km RB26
the other choice i'd look at for a stock GTR is the penrite 10w50, motul 8100 5w40 or even turbolight 10w40
Thanks for the reply mate.
Still a bit torn between 10w40 and 10w50?
And will a 5L bottle be enough for my requirements (have been doing some searching and seen the RB26 is approx 4.5 litres with filter).
But hard to get a straight answer through research on the internet (Some people have oil coolers or add extra for track days?).
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
