for $10 more I would be going for the full zinc Racing 10
http://www.penriteoil.com.au/pis_pdfs/010%20TENTHS%20RACING%20OIL%2010%20NOV%202012.pdf
I bought the 10 Tenths Racing 10 in a 20l drum for about $120.
Trouble is...
I can't remember if it was on this F/S forum or the OzFoz F/S forum - sorry
For normal service intervals on a road going car, the enviro 5w-40 would be a far smarter choice than the 10 tenths racing. Reason being that 10 tenths is ester based and only designed for short service intervals (one change per race day) and has a dreadfully short effective lifespan. I'm pretty sure it also doesn't meet or exceed any of the last 3 or 4 API ratings...
That sucks :(
Is Mobil 1 0w-40 okay to use in a non turbo r34?
Bit thin, try 5w-50
That sucks :(
Bit thin, try 5w-50
There is some truth in what he said there in that racing ten doesn't have the latest ACEA ratings like A4 A5/B5 like the Enviro but the rest is complete BS.
Racing 10 does have high zinc (ZDDP) which is good for RB engines especially Neo's and RB26's with solid lifters, oils with high zinc and phosphorous levels tend to clog catalytic converters faster and hence they don't meet the latest standards for petrol/ diesel economy engines designed to run in California with their strict laws.
It's service life is fine for daily driving, hence it's A3/ B3 rating...
For use in high performance petrol and diesel cars and light commercials where extended drain intervals are specified by the vehicle manufacturer and / or for year-round use of low viscosity oils and / or for use in severe operating conditions as defined by the vehicle manufacturer.
...probably one of the better oils to use in an RB!
Edited by Missileman
On my GT-R I went from HPR10 to SIN5 to Racing 10 (couldn't find Premium 5). The 10 tenths made the most noticeable difference, the engine runs smoother and quieter compared to the other two oils. Hopefully they last 10,000km lol.
TJZ - 10W-40 is not too thick, Nissan 200SX oil (from Nissan) is 7.5W-30, so 10W-40 or thereabouts is fine for daily driving. If you're thrashing your car a lot then look at getting thicker oil (5W-50 or 10W-60 etc.).
My apologies, I was about to start ranting and raving and calling you names when I thought I'd better check the Penrite website. It appears as though the formulation has been updated since I left the industry and now complies with the latest API (SN) rating AND they've done something about it's service life.
This will actually make my next oil change a difficult decision as I always like the ten tenths range based on its other benefits (friction/cleaning) :)
Thanks for the heads up (even if it was a little blunt)...
That's OK. It takes a man to update; even if it conflicts with previous info supplied.
One of the Z-Tunes in Oz was run on Elf Excellium SC 5W-40 which I then ran in my previous VS2.
I didn't have it long enough to see incremental changes at each oil change.
no apology necessary, some times i'm blunt, some times i'm sarcastic, a lot of the the time i'm just plain rude, i put it down to old age.
oh and I'm not trying to push penrite, in fact i've never used it, though i may give it a try next change.
I'm surprised they don't use something like Mainlube in such a rare motor!
Yeah, well it went off to Greece.
Probably not worth much under it's economy; but perhaps it can be resold in a richer country.
Back to thread, that Z-Tune was being serviced here in Sydney by an RB specialist.
The penrite 10 tenths is good stuff. I've used the Penrite racing 5 oil (now 10 tenths) since I got my old ford laser years ago with about 250,000k's on the clock. It's now done near 360.000k's and it's still going strong despite being given some hefty punishment over the years. I used to do changes every 10,000 but it's down to about 5-6000 now because it slowly gets noticeably more sluggish and rough after that in it's old age.
I've been using Penrite since I started driving. HPR15 in my R31 for 5 years no issues.
With my GT-R, went from Mobil 1 5W-50 to SIN5, engine ran noticeably smoother and the pressure was more consistent at 5,000 km compared to fresh oil. The 10 tenths is even smoother again (by not much).
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
