I was desperate to get a change done today so I just got the HPR 10. My oil reeked of fuel :(
niZmO_Man my (local) Autobarn had 10 Tenths Premium but unfortunately not the Premium 0W-50 which is what Penrite was recommending for me.
I’ll be getting some Racing 10 (10W-40) from Repco as per the suggestions above.
Thanks guys!
i use 10/40 tens racing with no oil control mods, car is regular daily and gets limiter bashing on the track days
picked up 4 bottles at repco for 55
try 10/40, then try 0-5w-50 on your next oil changed after that and note how much oil has been consumed
went from castrol to everyday penrite with the same grade on sisters daily and has fixed the power band issues it had
Edited by Dan_J
I use pretty much same have 250rwkw on my 34GTT and use 5w-40 even when taking out to track for drifting. I am going to put the 10w-50 when I head out to matsuri as it will be hotter then and a lot more track time seen than usual
Engine : Nulon hi tech fast flowing 10W40 synthetic + one bottle of Nulon E20. - Very smooth.
Gearbox : Nulon Semi-Synthetic 75W-90 Smooth Shift. - Tightened the box + easier cold shift / less crunch.
Diff : Nulon SAE 90. - Tightened up and stopped a reversing clunk.
Probably posted this before but all of these have improved my car. (Daily Driven)
Very Happy. :yes:
i cant say i know much but as far as going thicker grade with no oil control mods it might leave you with more oil in the head not draining back to bottom end due to thickness
others may have actual answers to this.
Can anyone tell me what is a safe oil temp for my r32 gtst? its a drift car with basic mods like a r34 neo turbo, hks intercooler, turbo back exhaust and a good cold air intake... also has some cooling mods such as a triple core alloy radiator, r34 viscous fan with shroud and large trust oil cooler with earls braided lines etc.
The oil is getting to 100 degrees very quickly, I always stop around then and let the car cool down but would be nice if I stay on the track for longer :) I was using penrite hpr 10 (synthetic 10w50) but have tried hpr 15 (15w60) and that made no difference.
Is there oils that are safe to use at say 120 degrees? Or could I possibly have an oil pump thats getting tired or some other issue?
any help would be appreciated :)
THanks
THanks
Oil temp of around 100 is pretty safe/normal I would have thought? My car sits on 80* day to day, and gets up to 90-95 quite quickly if I take if for a bit of a blast, and also comes down quite quickly once its been driven normally. I have a oil cooler in the front right guard that gets decent airflow
Im looking at using Penrite for my next oil change, seems to be quite popular
I haven't tried the 10 tenths range yet, would a different oil actually lower the temps? or just safe to use at higher temps? will a thinner oil cause less friction thus lowering the temp? I also change the oil about every 4 drift events...
I would be happy if it stayed at 100 degrees but it will keep climbing unless I go into the pits :( hottest I've let it get was 120
That's actually a pretty good point didn't even think of that. I may be better keeping my thinner oil since I don't have issues with burning of the oil or blow by
Yeah give Racing 10 (10W-40) a go. I think they have a thicker oil in that product line. These are $75/bottle, but they should be more stable when running at 100deg.
My car is street driven, but switching from HPR to SIN I found the temps stayed a little bit lower (barely detectable).
Still using nulon 10 40,near enough to 430000 ks now,fantastick stuff.
:thumbsup:
Genelle, try the Nulon Semi-Synthetic 75W-90 Smooth Shift (Gearbox) and Nulon SAE 90 (Diff).
Fantastick Stuff Indeeds. :wave:
  • Like 1
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
