I've been running Penrite Racing 10 for almost 2 years now, no complaints
From what I understand, this is a Group 4/5 oil?
Deciding on if I keep using this, or switch to Nulon Full Synthetic 10-40 Hi-Tech, does anyone know what group this falls into, and if its any better than the Penrite Racing 10?
You would need to shoot Nulon off an email, I would like to know also. Prenrite state clearly in their product information sheets that Racing 10 is synthetic PAO and Ester based.
If you're looking for something a little cheaper, I have been using Penrite HPR DIESEL 5 5W-40 It has a high Zinc content as well as detergent/ cleaners, works well for me.
http://www.penriteoil.com.au/products.php?id_categ=1&id_fuel_type=3&id_products=7
Edited by Missileman
I drop mine after every trackday. :)
I do scaling factor for track day kays - so any kms done on the track are multiplied by 5. So if i do 100kms at the track, that's equivalent to 500kms of regular driving. At this stage i have no evidence if this is sensible or not...
The reason people drop there oil after a track day is due to the amount of heat the oil sustains when being driven on the track.
Excessive heat on any engine oil reduces its effective life immensely.
If you find yourself in the higher rpms at a track day, you should dump your oil.
Also keep this in mind on the steet. Pending how you drive.
If you want to know for sure. There are places that analyze your engine oil.
My track oil temp is under control. IIRC Mobil say M1 is ok with respect to degradation at 150 deg C. Agree that oil temp has a very important impact on oil life, as does quality of the oil. So whether you need to dump after a track day depends on those and other factors. As you say, if you dont test the oil you're just guessing, but thats fine too.
I've been doing oil testing on the Stagea, and will do on the GTR next time.
  • 3 weeks later...
Hey guys just here for some advice:
I have read through the first few pages and I have a slight understanding but in my 33 it previously had some cold idle issues and the oil pressure was hitting 8 when driving... So I decided to change the oil and after asking around I decided to go with penrite 15w-60, though when I started it it seemed to have the same idle issue.. (Had it on for 2 minutes before I stopped as I was worried about the sump plug, which the head of the bolt snapped off...)
Any ideas? Using this car as my daily/track car!
Also like in the hills of Adelaide so it gets pretty cold here
Edited by Polishn
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
