That 10-40 everyday Shiite has been out for a while. Used it a couple of times in an sr20, seemed OK. I ended up changing to castrol edge 10-60 to try and stop my flogged sr from making its ugly sr noises. I don't have an sr anymore. I'm now an rb fan. I've got about 15 litres of 10-60 stockpiled in my shed. I'm wondering if it will be OK to run in the rb25?
that penrite extra10 shite confuses the crap outta me. is it a 10w30 or a 10w40?? package says may be used where 10w-30 is recommended.
everyday 10w-40 made the v35 sump seal weep oil, was all wet. switched to nulon 10w40, dry as... so does that mean penrite everyday is really a 10w30 with some extra "protection'?
Yep diesel engine oils usually contain higher levels of dispersants to prevent the soot particles from agglomerating.
Historically they have always contained higher zinc which has significant anti-wear properties. They got rid of zinc in the 80s because of catalytic converter contamination fears but recently started to reintroduce it into petrol engine oils.
I have used it since 2007 in my LS2 and for 5 years in my RB.
When I blew my turbo couple of years ago I pulled the sump off and it was amazing. No deposits at all.
This is a link to the post with picture of my bottom end after 30000 km of abuse.
http://www.sau.com.au/forums/index.php?/topic/22458-The-Goods-On-Oils#entry7381708
Edited by XGTRX
Technically, yes. It acts like a 30 weight oil.
If you put R32 GTR into Penrites recommendation guide, is says that HPR 5 SAE 5W-40 is the preferred one. The new, cheaper one may be a lesser oil.
It's just for my daily and the mrs car so all good. I use Castrol 10-60 in the GTR.
10w40 and 20w50 full syn oils should have everyone's bases covered,
I have no idea why anyone would want to use heavier oils in a high revving motor like an RB?
unless I had no oil cooler and I was bashing through a Dakar rally then maybe I would use a 60 weight
I use the the Penrite Racing 5 (5W-30) when I can find it on special, but most of the time I'll use the HPR Diesel 5 (5W-40) I have the Racing 5 in there now and it seems spin up a little quicker than the Diesel 5 that it replaced.
Will be interesting to see how the thinner stuff hold up during this summer.
  • 4 weeks later...
Repco has nulon 1040 in 6ltrs for 50 bucks absolute bargain,been using this for hundreds of thousand ks fantastic stuff,no lifter noise on start up and lasts for 10000 ks my ol 33 loves it.:-) :-)
  • Like 2
  • 3 weeks later...
Great sticky, did a bit of research and just bought royal purple 10w40 high performance Street for 92 bucks for 5 litres and nissan oem filter for 20. Will hit 5k service on the weekend. Car currently runs smoothly but would like to see the difference at the high end of things after the change.
I'm Betting none.
  • 3 weeks later...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
