I bought everything.. in some days I will finish my project but I see that I don't have any blow off valve!!
First of all... do you think that it is necessary for my setup?
In my previous engine I didn't have any problem (ca18det GT28R 20psi 350hp).
And if it is necessary which do you suggest me?
I will not run it higher than 27psi..
I like SARD R2D2 bov but it will work in an engine like mine?
Maybe Sard racing bov is better?
They selling this for HIGH boost aplication they said..
- High Endurance Valve Type
- Eliminate Air Leak At High Boost
- Super Hi-Response
- Easy Valve Spring Load Adjustment
But tell me for what ever bov's you use :P
I have a greddy type R and it's the only one I would reccomend (other than stock GTR's). Mine is also tightened down to the point where it only really blows off when I get up above 1.3-1.5 bar'ish. I like the flutter noise. I reminds me that I don't have a gay HKS SSQV limiting me to 1 bar of boost. I always get a kick out of some goober with a stock turbined R33 telling me I should get a BOV, and than opening the hood for them :P
yep, Greddy Type R is the way to go. It will easily bypass enough air for your turbo and boost level. and they are easily plumbed back in to the inlet or if you want they sell trumpet attachements too so you can vent it to atmosphere.
the sard R2D2 is like a toy BOV, mostly plastic. sard racing is better, but the trust Type R is better again, much bigger surface area means it can flow much more air.
trust type r here, i have the heavy spring in it and it never seems to open even on the softest setting, im running 18psi and 560hp at wheels at moment with a t04z
Agreed. The cost too atm, makes it a no brainer.
Hooking the OEM GTR ones up, takes up a lot of room unfortunately.
I got a type r for my setup it was easier to plumb in instead of the standard gtr items...I dont want to get into a debate about the no bov situation but you are seriously hurting your turbo and engine by not using one..
...its a high mount fellas... gtr bov's dont like not being plumbed back they open and shut all the time
No debate, they need to be plumbed back, but how does the turbos positioning effect it? :blink::)
An example that comes to mind is a famous dark metallic blue Perth 10sec BNR32 with a Z and OEM BOV's.
Edited by GeeTR
sure standard GTR is great but I would think if he's put an RB26 into an S13 the standard S13 BOV will be useless and the GTR bov is probably still with the car the engine came out of... also in an S13 it will be a bit of a hassle to mount the stock twin BOVs and their associated plumbing. so I would say in this case Trust Type R is the best and easiest way to go.
I don't have the stock gtr bov's and I cannot find any here in Greece!
Also stock are ugly and difficult to fit as I see some fotos.
Instead to pay for the stocks better to buy a Greddy!
I will go for Greddy Type R!
With strong spring or with standar?
I am not sure if it is better to return the air in the pipe between the turbo and mafs or vent it to the air.
Your opinions?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
