Hmm, N13 pulsar, I got it for free lol
I'd rate it 3/10, no ABS, no airbags, seatbelts were pretty bad.
I was lucky enough to not be involved in any accidents with it, But i've seen a few with my own eyes that got pretty messy.
One guy tryed to change lanes into a truck. He survived after being in hospital for a couple of weeks.
I saw another where someone crashed into one head on on the freeway cause he was drunk. The lady driving didn't survive.
Jeep Cherokee soft-top a mate used to own, 0/10. Complete and utter steaming pile of shit. No redeeming qualities at all.
Crap steering, crap gear-shift, crap brakes, rock hard suspension (odd for a fourby), bounced all over the place at pretty much any speed, and the finishing touch- the soft top would try to peel back on it's own at around 100 kays, and you had to hold the velco strap where it wraps around the frame to stop it from coming open.
Worst. Car. Ever.
Every Holden from the 50's - 60's atrocious on every level.
They'd be close to the worst cars built on the planet for their time.
But the king of the whole damn shitheap is the Fiat Niki aka Fiat 126...nothing comes close.
The fiat did have a slight go-cart quality about it..but other than that it's a shocker.
The early holdens, if any of you have driven them in stock standard form you'll understand.
0/0 and 0/0 for all
Edited by madbung
my old suzuki sierra, went over anything, but city driving, no sound deadening, no pwr ANYTHING, massive 4wd tread, low speed steering was unbelievable, 1.5L4cyl 42kw... was worth it though very fun car lol. 3/10
Edited by 2BNVS
You're Spot On!
Low Speed Steering and especially Low Speed Stability beggars belief!!
I'm waiting patiently on Silverwater Rd some years ago at the lights, ready to turn right onto Victoria Rd.
A Sierra driver turning left into Silverwater Rd doing about 50 I guess, tips the thing over; and then it slides over to our car and stops 2m away.
More unsafe than any Skyline with CF bonnet, no windscreen wipers on a rainy night being controlled by a driver in the passenger seat...
T
1979 Honda prelude
No ABS, no airbags, shitty seat belts, hand brake didn't work, brakes sometimes didn't work, rust all through the body (badly)
I would give it a 2... I am actually surprised the doors never literally fell off considering the amount of rust it had in there...
my cars id give:
3/10: 1986 4x4 toyota hilux
(shit suspension, under brakes rears lockup very easily due to alloy tray, no power steering with play in steering)
7/10: 1992 r32 gtst
(rough ride but suspension is good and awesome brakes, awesome steering, very safe car in comparison)
note: obviously things like airbags and side intrusion bars make a car safer in the case of an accident
but for me the way a car steers and handles makes me feel safe (or unsafe which ever the case might be!)
1985 toyota hilux, fell asleep one day on the way home from work, ploughed into a motorbike i was doing around 60, he was doing 50, all i got was a scratch on the number plate while his bike was parked under my front wheels, he landed in the well side, apart from a saw ass ,he was ok.
:) I dont get it... :thumbsup:
:P I dont get it... :)
...something to do with Post #15
When you have a bike under the front wheels, brakes lock up, there's no steering and suspension goes spongy.
Don't take my word for it though... :thumbsup:
wasn't there a car that would just explode if it was hit from behind with a bit of speed? i'd say that'd be the worst. Apart from that i once saw a corolla with about 2 feet of mattress foam on each panel so i guess that has to help . . . .
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
