Yeah that ^^^^ could have ended up SO much worse than it did!
funny how Mum's body is so much better than the daughter's too huh.... Kojak biting the big one cracks me. I know I shouldn't laugh, but hey.... they all survived :)
Heya all :)
Anyone looking for a crew member to help out at High Country?
The guys I usually help out have other obligations and won't be attending.
Spanner experience on mainly Jap cars, lots of rotary experience, prefer modern.
Currently working on Radicals and Lotus' but spent time solely on Nissans (GTRs 32/33/34) and Mazdas (RX/MX5).
If it whooshes, I can spanner it.
I like cider and KFC tower burgers.
Check http://www.tarmacsolutions.com.au/ and follow the Facebook link at the bottom of the page for further info.
Sydney team preferred.
PM/email if you're interested.
Mark :)
Update big guy? Some pics? Something..... anything!!!!
Not much to update Woo, been spending too much time working and skiing. Have lost about 100hrs trying to get some weight out of the thing! First 30kg was easy, but spent 4hrs last weekend for a 2.5kg gain..
Still looks the same, and will run like that. Fitting intercooler, bigger brakes, some spring/swaybar upgrades and tighten up the diff. Besides that and the diet will be pretty much as I bought it. Out of time for anything more, but if THC goes well then round 2 of upgrades for TT13. I have attached an engine bay picture to keep you happy, not that exciting really
Thanks mate :)
What pogo sticks is she running and is the under bonnet colour factory or has it been painted race-spec silver?
Will you get a chance to give her a run in anger prior to heading down?
I spotted that one on MY105 and got a bit misty in the duds, would be a good, albeit mildly expensive, base car.
So, importing a late model left hook Porsche from Europe specifically for tarmac rallying and planned to be on rally rego or even Tassie "special interest" rego..... IS LUXURY CAR TAX payable?
Can't seem to get a definative answer on this yet? Anyone here got knowledge?
Weren't some dudes importing them from the States cheap and having the engine/trans removed and shipped separately to avoid something like this?
Sorry can't help on your actual question, its a very open for debate question though.
Car is well and truly over the LCT threshhold.
Not heard that Timmy?
Possible exemption
Below is an extract from a conversation;
The definition of ‘car’ for LCT purposes is broad and covers basically any road vehicle. The only potential avenue to avoid LCT is the fact that a ‘car’ does not includeracing and rally cars that are not road vehicles and cannot be registered for use on public roads in any country in the world. These racing or rally cars are designed for use only on rally or racing circuits.”
SIGNIFICANT work would need to be done to ensure the thing couldn't be registered "in any country in the world"... and who would be the judge of that?
Does it just need a cage installed? The engine removed? Cut into little pieces?
Keith Johnstone has just bought a 996 GT3 for a rally car and bought it from the UK or somewhere, don't know if it was already caged or what. Maybe if you can get in contact with him or Pete Nunn they might be able to shed some light.
Further to that, if its a left hooker, it wouldn't really be road registerable would it? So it wouldn't be eligible for LCT?
Would CAMS be able to help you? Maybe talk to your State Club and Development Officer?
Keiths is a damaged GT3 RS with a factory cage.... and is probably a '20t excavator'. His 944 is a left hook, and rego'd as SI
I think there is some trickery you can do with how you pay for it to get round LCT. Buy the 'car' with 1 cheap payment, and they pay separately for the parts. If it's all done o/s it's hard to prove the price
The yanks have really weird rules, and they have to dismantle cars, and bring them in as 'parts'
Edited by sav man
That race car rule is why 911 GT3 Cup's are so well priced from new, because an undertaking is made on import by PCA that these are race cars and not eligible for rego. Under the federal import approval of the Panno as a rally car (to suit SI rego requirements) it will identify it as rego eligible under state delegated authority…
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
