Well, i have finally decided and put a deposit down on an engine conversion kit for my N/A R33, I will be getting the engine from Just Jap, and with 31,000Km's on the clock, i think that i have done pretty well ;) , the only problem is now i have to wait!!!!
The half cut is still coming in from Japan and will be in Sydney in a few weeks after that, it needs to be pulled apart and freighted here :)
Anyone in WA ever done a conversion?
Also without an LSD will i be missing out on much, and with the rear hubs not being changed (from 4 stud to 5 stud) will this be an issue (my rims are 4/5 stud type rims so that doesn't really cause an issue), should i just by the rear hub assy, and brakes to keep it consistant with the front?
Thanks, pretty excited, but won't be excited until i'm behind the wheel of my car with the new engine.
Kris
https://www.sau.com.au/forums/topic/23138-na-to-turbo-conversion-the-big-move/
yes well that may be true, but back when i got my GTS i could not afford insurance. Now i can but have loans outstanding, and rather than sell my car (which i have tried and failed) i thought i might convert it, it gives me something to do, and i like my car anyway.
Guest neoGT-25
Hey all, a south-east queenslander here :)
congrats on the -t to your gts skyliner33wa :)
ummm... i have a non turbo R34 right... i want to get me a R34 GTT 1/2 cut in a few years but my friend was giving me an idea and i dont know enough about it to consider it seriously... he was saying if i got a rb30 bottem end and added a rb25det neo head that i would pretty much have a rb30det neo... is this concept right or wouldent it work??
sorry to theive your thread :)
thanks guys, well yeah i and my sisters boyfriend will be doing it, so labour will be free which is cool, i just want a standard GTST fro now, have always wanted one now i have made the move, i know that its gonna cost me alot but you only live once, plus i'm still young. I am getting the rear Hub Assy so, all i am missing out on is the LSD, i don't mind
Thanks
Kris
i was thinking of doing the same thing with my n/a but have been told by most people that its a lot easier 2 jus buy a GTST because ill have 2 change the engine, brakes gearbox blah blah blah and it will take a long time
also just wondering wat does it get insured as? a modified GTS? or a GTST? and because it wasn't originally a GTST does this mean that insurance will b higher then a GTST?
well, cause me and my sisters boyfriend will be doing it labour will be free, yeah it would be easier to buy a gtst but i can't afford it, plus i wanna do my own thing, about insurance, havn't really found that out yet, but i will tommorow, got an insurance broker i'll go thru
  • 6 months later...
Hi,
just interested to know how much it cost for the engine and parts etc, i will be looking to do the same thing in a year or so and want to know as much as possible before i go ahead with modifying my GTS..
also just a thought but for the same amount of money, is it just easier to get the same amoun tof power or more from the RB25DE?? leaving it N/A?
:rofl:
this would be a perfect oputunity to do a rb30det conversion insted, pity you have already purchased the front cut.
You should really ask these questions BEFORE putting money down.
werd.
for those talking about turbocharging an NA, and who havent yet committed funds, get yourself to the induction performance thread on this site and read about Rb30dets.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
