R33 GTR. 2.8 litre with a pair of RS's hanging off the side of it. 380 - 400 RWKW or there abouts.
Late model box in it only having 11,000 KMS on it and i stripped 3rd. Made a good mess :(
Now have the OS 1-5 + input in. Ill get back to ou on how it is on the street.
I think most people will agree that a gearbox is like a clutch. It really depends how you treat it.
So far iv'e had no problems with a stock 5 speed box and similar power levels. However, when I take the car to the track it may be a different story. I know the stock boxes tend to let go in 3rd but sometimes this can be attributed to harsh clutches and particular brands.
I am also interested in feedback from people using these aftermarket gearsets.
When my box let go I was giving it a hard time (8000 rpm change from 2nd to 3rd) but knowing that 3rd is a weak point i was always very tip toey into 3rd, this gear change being no exception. Clutch is a Nismo twin plate coppermix which may or may not have helped but atleast it has a sprung centre.
R32 GTR, 3 years ago when it had 400hp atw stripped 3rd gear when shifting from 2nd, felt weird sloting (worn synchros?) in for a split second then bang, had os triple plate.
Also snapped a uas pivot ball a few months ago.
If money is no problem then I'd will/would go an os, ppg gearset to handle the hp.
R32 with 430 RWHP. 80K on the standard box. Little bit of short track and a few drag passes. Syncros going
The OSG 5 Speed kit is going in as we speak-there is a thread in this sub forum. I will post the complete parts list when I get home
From memory a standard GTR gear box can take up to 500kW but all depending how you shift gears and how well you treat it.
I think a Getrag 6 speed would be quite good and I was told a Holinger 6 Speed was real tuff.
Dont think that a Getrag 6 speed (r34 'box) is really the answer, if ur breaking GTR 5 spds, then ull prob break the Getrag 6 speed
If i had one and it broke, id be looking at the OS Giken gearsets, either the 1-3 or 1-5, or go Aussie made and go for a PPG gearset.
I looked at the Getrag as an option but in the end I went for the OSG kit...from what I could gather the Getrag GB rebuild was a pricey endeavour.
As for a standard box with 500Kw..I suppose you can put any Kw through a box is you baby it. I would think 400AWKw would wear a 32-33 box out pretty quickly if driven with any verve
One of my friends had a Trust gear set in his 32. He use to race the car. He liked the gear set, said it took him a while to get use to it, but the harder you changed gears the better it was. Don't know what it would be like for a street car though.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
