Had to order a new key so bought some other bits too.
Clear lenses for the interior light - seen them on the US forums so i thought i'll try
Door finishers - they haven't got it right with the rubber coating on these door handles(2007), they still scratch just as easily like on my r33.
In saying that the coating does look thicker with these new door finishers.
Part numbers in case another else needs
  • Like 1
How much were the handles?
Great, thank you for the tip off - I ordered mine today. Strange the rear door switch trims are double the price. They can stay as is, pretty good condition anyway.
I had a look for the steering wheel plastic trim but couldn't find it on amayama. Anyone else been able to find this part?
Got them through www.amayama.com
Used them twice now and pretty happy
  • 1 month later...
Alright!!! Finally ordered Eibach Prokit from Eibach Australia, took 5 days to get here, and were installed 3 days later. Sits very very nicely and extremely happy. Exact same comfort, doesnt even look that bad with my stretched low profile tyres lol.. theyre only super stretched 30's on the front and 35 years and id say sits great, may in future put 35 front and 40 rears and the gap will be non existent.
809 - front door trimming (trim) for Nissan Skyline PV36
http://nissan.epc-data.com/skyline/pv36/7257-vq35hr/body/809/
828 - rear door trimming (trim) for Nissan Skyline PV36
http://nissan.epc-data.com/skyline/pv36/7257-vq35hr/body/828/
990 - emblem & name label (body) for Nissan Skyline PV36
http://nissan.epc-data.com/skyline/pv36/7257-vq35hr/body/990/
Best-selling parts for Nissan Skyline PV36
http://nissan.epc-data.com/skyline/pv36/7257-vq35hr/quick/
  • 3 weeks later...
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
