nah wont be dropping it.
The roads around my way are a joke.
Cant even get in the servos around here as it sits.
I had a EiBach lowering kit but sold it ;)
cheers for the kind words guys
I got the Eibach springs on mate, car looks great - Ill have to get some new pics up as soon as it stops raining so I can wash it :down:
Hey guys,
Have added a couple of bits to the car. Took some photos with the iPhone, so excuse the quality of the pics:
• CF Rear Diffuser
• US Battery Cover (to cover the right side of our engine bay)
• CF Hood Hampers
• Eyelids
The USA G35 forums say that the cheapest version on Ebay is a POS, but the more expensive one is rather good fitment and look. From memory the cheap one is around US$200 + shipping and the god one is US$400 + shipping.
After a good two months of waiting for my order to be shipped. My Inven front bumper for the coupe finally arrived from the U.S. Will post pics as soon as its fitted with my impul sides.
Edited by CRISP 35
I got the Eibach springs on mate, car looks great - Ill have to get some new pics up as soon as it stops raining so I can wash it :thumbsup:
good to hear. :thumbsup:
I would have loved to use them but have trouble at the stock hight.
Cant wait to see some pics
^^^ looks great .... what are the width and offset of your wheels?
thanks for the comments.
19 x 9 +22 (F) on 245/35R19
19 x 10 +22 ® on 275/35R19
no rubbing but then again i haven't dropped it and i travel light. read somewhere here that the max width at the rears to avoid rubbing was 9.5" at +22 but the extra rim depth was too tempting.
Thanks for the info. I bought my LMGT4s in 9.5 +20 and the fronts are perfect but the offset on the rear is sadly lacking. Once I lowered the car it severely cambered in (and looked very shite), so I got some SPC rear camber arms, and the alignment workshop brought the camber from 4 degrees back to about 1.5 degrees. Looks a bit better now, but I definitely agree with your 10 +22s on the rear - I am going to buy a pair of 9.5 +12 or 10 +15s for the rear of my car to make it look better. In fact I am going to try some 20mm bolt-ons for a car show this weekend, so we will see how she runs with 9.5 +0 :wacko: - I will post pics next week. Note too I am running a stretched 215 on the front and 235 on the rear (I like the drift look), so will get no rubbing.
Nice wheels :wacko:
My 9.5 +18 rears, wearing 275 wide tyres, were VERY close to scrubbing. In fact one of them was scrubbing until i had the camber adjusted (using the factory camber bolt).
I've since had my guards rolled and dropped the car even lower. I'm now suffering the same problem as nightcrawler. It has caused additional camber and the wheels tuck-in too much, looking much crapper than before.
My plan of attack is to eventually fit some spacers and slightly stretched tyres (245 maybe). Night crawler, if you could throw up some pictures of your setup with 20mm spacers, it would be really appreciated.
Thanks for the info. I bought my LMGT4s in 9.5 +20 and the fronts are perfect but the offset on the rear is sadly lacking. Once I lowered the car it severely cambered in (and looked very shite), so I got some SPC rear camber arms, and the alignment workshop brought the camber from 4 degrees back to about 1.5 degrees. Looks a bit better now, but I definitely agree with your 10 +22s on the rear - I am going to buy a pair of 9.5 +12 or 10 +15s for the rear of my car to make it look better. In fact I am going to try some 20mm bolt-ons for a car show this weekend, so we will see how she runs with 9.5 +0 :banana: - I will post pics next week. Note too I am running a stretched 215 on the front and 235 on the rear (I like the drift look), so will get no rubbing.
no prob. your set up looks great judging from the track pics you posted and the wheels look hot. front is perfect already and putting on the spacers at the rear should bring it out to match it. looking forward to the pics.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
