Which Stroker Kit
177 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Tomei hasnt released that much info on rating but i have reading up on it alot and seem find its rating is about 600ps (441kW) to 800ps ( 588.40KW)
anyone making over 400kw in there GTR will be more than happy to keep it at that level. so theres no point getin the HKS step 2 or 3 for that extra pwoer level
you say you payed $7500 for the HKS kit which is not bad. but i would of gone the Tomei kit for that same price
The 7k TOMEI 2.8 stroker kit is cheaper as it does not have a full 12 counter weight crankshaft it only has a 8 counterweight crank so for circuit use i would prefer the HKS step 2 2.8 or the jun 2.7 as both have the full 12 counterweight crank.
  • Replies 168
Posted Images
u guys are missing the point the guys wants to know which is the best stroker kit out there.
i think the Tomei is still better than the HKS. as the tomei item has a Bore 87.5mm with brings the cc to 2807 $ 7,649 which is cheaper than the HKS step 3
which the HKS stroker kit Step 1 Bore 86.0mm, Step 2 Bore 86.5mm, Step 3 Bore 87.0mm $10,000
the steps of the stroker kits have nothing to do with bore size. you have the option of 86.5 and 87mm with most of them.. some have 87.5 and 88mm which i wouldnt think about doin if your pushing a motor anywhere near its limits while hoping for reliability
they have everything to do with bore size. "Cubic centimeters. It's a measure of displacement. Displacement is "bore x stoke" or the cross-sectional area of the cylinder times the distance the piston travels in the cylinder. The larger the bore and the stroke, the greater the displacement"
end of the day people are pay alot of my for a stroker kit and they want the most out of it. yes reliability is one of them but having more cc with a bigger bore size always win's.
the step 1 2 and 3's mean more than just bore size. heres the hks kits brief run down
Step 1, pistons rods and crank
Step 2, pistons with coatings rods and crank
Step 3, pistons with coatings and billet rods and crank
the tomei step 1 and step 2 are slightly different with the step 2 having the cooling channel pistons
Are cooling channel pistons REALLY needed?
I have the Tomei stroker with NON cooling channel pistons and have had no problems what so ever.... Thats with a "tight" 2 thou piston to bore clearence.
if the 3.4L stroker was available i wouldn't mind giving it a go. due to the displacement you wouldn't have to rev the engine to get a lot of torque and power but if you balance the thing well it should have no issues doing 8000rpm there are many RB30 engines doing 8000-8500 rpm how much more do you need?
^they certainly arent cheap by any means.
Out of interest how much does it cost to to fully prepare a stock crank for your average tough drag/track engine?
Martin HKS, whilst your here, can you comment on the power handling of the HKS step1/2? ive read that they seemingly use very similar components in the kits, and that even a step one kit should be good for far more than its 600ps rating. This would be good to know as there is a significant price diference.
Here is the HKS breakdown on kits. We all know you can run them a lot harder than HKS recommend just like stock.
They are all 2771cc displacement using 77.7mm full counter stroke crankshaft and 87.0mm bore. Step 1 and 2 have 21mm pin while the discontinued Step 3 used 22.0mm.
HKS Step 1 = Forged Crank, Piston, and Forged Conrods
HKS Step 2 = Lightened Forged Crank, Nickel Coated Pistons with Titanium Coated Rings and Forged Conrods
HKS Step 3 = Billet Crank, Nickel Coated Pistons with Titanium Coated Rings and Forged Conrods in 22mm
Cheers
Marty
Edited by Martin HKS
From the sounds of things, I'm starting to look into the JUN 2.7 kit, HKS and Tomei 2.8(its kinda hard for me to get rb30 parts here in America hehe). From What I have seen the guys from CRD like to run that kit. I so want something that "revs like a sewing machine" LoL. The only issue now is my turbo size(I'm starting to realize that its always something else that needs to be figured out after you answer one questions). I want to go top mount twins that are externally gated, but im not sure what size turbo I should get. I've seen a lot of cars (via youtube, streetfire, magazines, etc.) running these big twins on top like in this video,
, but I can never find what size they are.
Its kinda funny with this forum though becuase I wait up all night for a response browsing this forum, but I always seem to forget you guys over there are on a completely different time zone that I am :( LoL!
But in all seriousness, this is the best, most helpful, nonbashing forum I've ever been on. And I really do appreciate all the help you guys have given me thus far and know I can always count on the right answer from you guys. :)
Being a broke ass Skyline owner, i have to question is the extra little bit of response and the extra few kws really worth the expense? I mean, have a holiday at Lake Como and have a 370rwkws rebuild, or sit at home and hope you can feel the difference between "fark me dead" quick and "i cant feel the difference" quick but the clock says i am going quicker?
This is why I said go RB30, you can blatently tell the difference. One of the ones RIPS in NZ built for a customer makes near 500kw @ wheels on pump gas, and has more power EVERYWHERE than what it did on the stock R34 turbos. If he replicated the exact same turbo/cam/power level on the RB26 then it'd be a different situation altogether.
The cool thing about extra displacement is that it has more torque all by itself, if you add boost it just piles it on - if the RB30 had the same boost curve as an RB26 it'd make more power all the way through the rev range. The thing is, the RB30 spools the turbo(s) harder as well so it will make even more power everywhere in the rev range - so you may as well counter that and get an even bigger turbo which is the same if not a little laggier than the ones on the RB26, make more power/response all the way through the rev range, and make a metric crap load more up top with no compromise.
As I have perviously states in one of my pervious statements, It is dam near impossible for me to get my hands on an RB30 bottom end LoL. And I'm sure as hell not paying our my arse hole for the OS Giken Kit no matter how many people say how good it is LoL.
But the RB30 would be my choice if I wanted to do with a BIG signle LoL.
I'm just so undecided on what I would like this build to result in .... I've just got so many thoughts going through my head with all these possibilities LoL :3some:
9's can be done quite easy with a well built engine using mostly stock components...Take our old set-up as an example.
STD 05U block
86mm Aries pistons
STD rods
STD crank
Mildly ported head
STD valves
STD springs
STD retainers
Tomei 1.2mm head gasket
Tomei oil restrictor
Tomei cams 260 9.15mm
Tomei sump baffle
N1 oil pump
N1 water pump
This ran low 10's with full weight 1600kg+ including driver using HKS 2530 low mounts and running Federal street rubber.
Car was ran flat out for 3 years before the rear turbo failed due to oil starvation (blocked oil feed) and when the engine was pulled down it was in perfect order.
The addition of one or more of the following would have seen high 9's
Bigger turbo's
Better rubber
Lighter car
Dog gearbox
NOS kit
Better driver
Edited by DiRTgarage
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
