  • 3 weeks later...
  • Replies 120
Posted Images
  • 4 months later...
Anyone seen or heard from Karl?
He seems to have dropped off the face of the earth
Sorry guys.. Mrs had a baby, working and trying to finish of my project car.. Back on board now.. I may not be here all the time, but i do check my emails for new messages. I can still make all the parts that i made before.
I have tried fitting my fitting Karl and they seem a bit slack in the cam covers. Wonderign if I should put some paint on the covers before trying to fit to give it that extra little tight fit that it may be needing? your thoughts?
Hi,
Sorry for yours to be a little slack. I make my parts based on the rocker covers that i have at work and this is the first instance i have heard that the fitting was a little loose as others seemed to be ok.
I do not mind replacing them if you like, as i like to keep everyone happy.
On the other hand you can just put some locktight on them or even a dab of silicon to make them tight or if you get the covers painted that will work too. Its not nesessary to make them tight (individual choice i guess). The main thing is that they do not leak, and as its not under extreme pressures it is unlikely to leak.
Please let me know and i will try to help you out.
Hope this helps.
Karl
Hi,
Hope this helps.
Karl
Hey no worries, I will give it some paint and probably use the loctite on it in any event. Work is top notch and me being in Trinidad for a replacement I think is too much of a hassle to give you anyway.
Cheers.
If anyone has the factory drivers side elbow let me know i will buy it off you.
Sorry can't help.
Can't wait for summer to come and finally get the car down calder when it opens up again.
Thanks for your support. I have some seconds of parts that i am keen on getting rid off (rocker cover fittings RB25) Make offers. The only thing wrong with them is that they are little rough on the treaded section (nothing serious just a few chadder marks on them) and when fitted you will not know as the visual section is normal. They WILL tighten as per normal. I think i have only to suit rb25 though and there is about 4 sets. All offers considered, but you pay for postage if needed. These are the parts that karl rejects although functionaly perfect.
Thanks
Karl
  • 4 weeks later...
im after a set of rb26 ones
pm me details plz
or i might be able to pick up as im s/e melb aswell
x2 for the RB26. I'll cover shipping to canada for the right price. Are the fittings compatible with earl's or goodridge connectors?
Edited by NismoSTune
Hi. I don't see why they will not work on the earl or goodridge style. The dash style (speedflow) are imperial sizing (u.s) so they should work. I think that its a standard they all work to for fitment
If you need 2 pairs i will throw in regular air mail to canada.
Let me know,.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
