  • 3 weeks later...
  • Replies 120
Posted Images
  • 4 months later...
Anyone seen or heard from Karl?
He seems to have dropped off the face of the earth
Sorry guys.. Mrs had a baby, working and trying to finish of my project car.. Back on board now.. I may not be here all the time, but i do check my emails for new messages. I can still make all the parts that i made before.
I have tried fitting my fitting Karl and they seem a bit slack in the cam covers. Wonderign if I should put some paint on the covers before trying to fit to give it that extra little tight fit that it may be needing? your thoughts?
Hi,
Sorry for yours to be a little slack. I make my parts based on the rocker covers that i have at work and this is the first instance i have heard that the fitting was a little loose as others seemed to be ok.
I do not mind replacing them if you like, as i like to keep everyone happy.
On the other hand you can just put some locktight on them or even a dab of silicon to make them tight or if you get the covers painted that will work too. Its not nesessary to make them tight (individual choice i guess). The main thing is that they do not leak, and as its not under extreme pressures it is unlikely to leak.
Please let me know and i will try to help you out.
Hope this helps.
Karl
Hi,
Hope this helps.
Karl
Hey no worries, I will give it some paint and probably use the loctite on it in any event. Work is top notch and me being in Trinidad for a replacement I think is too much of a hassle to give you anyway.
Cheers.
If anyone has the factory drivers side elbow let me know i will buy it off you.
Sorry can't help.
Can't wait for summer to come and finally get the car down calder when it opens up again.
Thanks for your support. I have some seconds of parts that i am keen on getting rid off (rocker cover fittings RB25) Make offers. The only thing wrong with them is that they are little rough on the treaded section (nothing serious just a few chadder marks on them) and when fitted you will not know as the visual section is normal. They WILL tighten as per normal. I think i have only to suit rb25 though and there is about 4 sets. All offers considered, but you pay for postage if needed. These are the parts that karl rejects although functionaly perfect.
Thanks
Karl
  • 4 weeks later...
im after a set of rb26 ones
pm me details plz
or i might be able to pick up as im s/e melb aswell
x2 for the RB26. I'll cover shipping to canada for the right price. Are the fittings compatible with earl's or goodridge connectors?
Edited by NismoSTune
Hi. I don't see why they will not work on the earl or goodridge style. The dash style (speedflow) are imperial sizing (u.s) so they should work. I think that its a standard they all work to for fitment
If you need 2 pairs i will throw in regular air mail to canada.
Let me know,.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
